Well, this has wasted 2 hours of my life.
I cannot get the feed shaft back in the worm gear properly. See the attached pictures. The shaft is pushing the gear up so much its hitting the bearing collar, and as you can see from the open end image, the shaft wont go up high enough because of that to fit into the hole.
Gear Hitting Collar
Shaft
Shaft cant get into exit hole.
Gear Hitting Collar
Shaft
