DaveC
- Jun 4, 2006
- SF Bay Area
I've discovered that my backgear's outer sheave bearing (PN EE-3715) has a broken keeper and will need to be replace. Does anyone know to get that bearing out? I've got the bearing exposed and the snap ring removed, but it doesn't seem to want to slip apart. Is it a press fit? The manual is unclear on this since this detail was apparently redesigned in 1966 and my (new) 1959 manual doesn't have the correct revision of this print.
Also, I'm concerned that the sheave's shaft (the part with the big spline and gear) may be damaged, since the shaft spins freely while the bearing remains stationary. Is this normal behavior with the bearing apart?
Thanks in advance for any info!
DaveC
10EE SN 41978
DaveC
10EE SN 41978
