10EE Collet Nose Runout - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
  1. #41
    Jun 2016
    New York
    1,759
    1048
    809
    címon now Bill, ya think I donít know to stone off a burr? think I donít know a taper ďshouldĒ register to a ten thou or less? Iím talkin bout shit thatís far gone should STILL repeat to a half thou or better, but it canít if itís teetering back and forth on a crapped or off spec taper, (or if itís not touching tapers at all like rimcanyonís), but it can if it sucks up flat to flat while locating on the taper.
  2. #42
    Virginia
    28,788
    7561
    8936
    Quote Originally Posted by cyanidekid View Post
    c’mon now Bill, ya think I don’t know to stone off a burr? think I don’t know a taper “should” register to a ten thou or less? I’m talkin bout shit that’s far gone should STILL repeat to a half thou or better, but it can’t if it’s teetering back and forth on a crapped or off spec taper, (or if it’s not touching tapers at all like rimcanyon’s), but it can if it sucks up flat to flat while locating on the taper.
    Hopefully, we ALL have the wit to stone a burr. It isn't ABOUT sloth. We presume "best practice". Or at least we hope we may!
    But that "flat" still has only limited effect as to establishing axes of position and stability. Axial or "longitudinal" primarily and most obviously. Pitch and yaw automagically.
    Radial displacement or "runout", OTOH is most specifically NOT even on its LIST any more than a faceplate has a "natural" self-centering action whilst a conical "center" has nothing LESS-than.
    Grammar-school geometry, "101".
    A truncated right-circular cone or "taper", OTOH? Perfectly healthy or somewhat less-so, it still controls ALL axes as to position. D1, A-series, L-series, Hardinge taper, Cazeneuve all make use of the cone taper first, a flat, if any, is secondary when used at all.
    That basic. That common to all tapered spindle mounting and locating systems.
    Make use of that to advantage. Don't piss it way.
