Brandenberger
Hot Rolled
- Sep 19, 2017
Hi,
I'm working on removing the saddle and apron on my 1962 10ee ELSR. I've read many threads here which were helpful, and I've already removed the ELSR control rod via the round 3-screw cover. Thanks to everyone who has thoroughly documented various aspects.
I now need to remove the bracket itself, and have seen various procedures described which imply the ELSR end bracket could just come off the leadscrew (leaving the bearing assembly attached)?
I am finding however that while the feed rod seems ready to release from the end bracket, the leadscrew seems to be firmly fixed into the end bracket.
The bracket itself attaches with the two SHCS and two threaded taper pins, all of which have been removed (not in the pictures, but when attempting to remove the end bracket). WHen the taper pins and SHCS are removed, the bracket itself can be pulled away from the lathe bed, so it it clearly not hung up on some other screw or pin I've missed.
I could of course remove the leadscrew and feed rod and slide the whole assembly out, if that's required.
Phil
Phil
