10ee missing taper attachment leads to problems: - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Oct 2018
    Ohio
    207
    185
    37
    Ok, so here is what I came up with. After a lot of thought about mounting an L-Bracket to the drawbar, I felt this was the better solution. Two final trims of pocket depth of .015 then .008 let the "bracket" hold the thrust bearing block securely without any undo pressure on the bearings. Permanent and out of sight. Don't know what to tell you guys these pics are not sideways on my phone or computer.
  2. Likes Mac007 liked this post
  3. #22
    May 2003
    4,664
    355
    That looks like a great fix!
  4. Likes Zap921 liked this post
  5. #23
    Oct 2018
    Ohio
    207
    185
    37
    Quote Originally Posted by donie View Post
    Thanks donie! Glad to be back turning threads again. Appreciate everyone's input.
  6. #24
    Oct 2018
    Kentucky
    185
    10
    40
    Quote Originally Posted by Zap921 View Post
    Excellent Thread and very neat fix. I own a Monarch CY and know that you can't run without the taper attachment for the same reason. There are CY's without taper attachments and would think there EE's without the taper attachment. A lot fewer parts and different internals in the CS control...
    My problem with Monarch Taper attachments (at least the CY) are extremely heavy and significantly contribute to way wear...
  7. Likes Zap921, Mac007 liked this post
  8. #25
    Feb 2019
    Michigan
    155
    34
    41
    I had not thought about the added wear on the back flat-way due to the TA's weight.
    I guess that a copy of that very nicely done nut-capture block could be installed and the TA set aside for the rare occasions it
    is used ??
    DualValve
  9. Likes Zap921, TheOldCar liked this post
