10EE Motor Generator starting problems - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Mar 2016
    Louisiana
    510
    258
    97
    Quote Originally Posted by Karl_T View Post
    OK, this whole thing is likely to just go south, but I will try a bit more.
    So, what the heck is an exciter - never heard of it. I know some have three wires, some have two wires. is it tiny like a resistor?? maybe inside another panel?? Now I am somehow supposed to find these wires and disconnect them. Got no wire numbers, no prints.
    Everybody is ignorant on some subjects and expert on others. The instructions Cal wrote up assumes the individual has a basic understanding of how a 10EE drive works. I have NO CLUE.
    Now I wrote the machine language code behind two line G76 for lathes. No way would i expect someone here to know how to diagnose a problem with this.
    Anyway, i would appreciate help, but telling somebody how to fix a problem at a distance when the guy is ignorant is difficult at best.
    The exciter is located on the top of the motor-generator driven by a belt it is not small it is a dc generator to generate the field voltage for the main motor and for the relays around 115 VDC.
  2. #22
    Apr 2011
    Wisconsin
    452
    186
    104
    Quote Originally Posted by labeeman View Post
    yup the "exciter" is the generator that is belt driven ontop of the main motor generator. It provides all the control voltage for all the relays switches and what not including the field voltage as labee said. That is why it is so important to understand if this is working and get it working if it isn't. The output of the exciter is available to measure on the terminals of E1 and E2 as Cal or someone mentioned.
  3. Likes labeeman liked this post
  4. #23
    Jul 2011
    Utah
    1,123
    2750
    479
    DON’T give up. I’m electrically dumb, but my 10EE’s work thanks to listening & studying here. My MG drive was acting exactly like yours. Search all posts on 10EE exciters. It is WELL WORTH IT. And you will likely be surprised when you find the culprit. As in, NOT a major failure.
    I have been in the “just get a VFD & 10HP motor” panic mode PLENTY of times. I am SOOOOOO GLAD I listened and learned here instead.
    You can do it!
  5. Likes rakort, labeeman liked this post
  6. #24
    Oct 2004
    Iowa
    3,330
    114
    500
    An easy way to recover a 'lost residual magnetism' circumstance WITHOUT flashing a field:
    Take a strong magnet, put it in a plastic bag, and stick it to the side of the generator as it's running. It will place a magnetic field in the generator frame, frequently it'll be strong enough to wake up a sleeping generator.
  7. Likes Karl_T, TheOldCar liked this post
  8. #25
    Virginia
    19,707
    7561
    11847
    Yep, finding electrical help on a 10EE is impossible in my location. That is why I ripped the DC drive out on my other 10EE. On the old one, the DC drive looked BAD.
    On this one all the components look to be clean and in nice condition, especially the DC motor and backgear. Does this motor and drive have any significant value?
    Looks like I am back to plan A - install 10hp 8 pole 3 phase motor and VFD drive - no backgear.
    10EE drive VFD no backgear
    Found the motor for $1500
    10 hp electric motor 284t 3 phase 900 rpm severe duty PE284T-10-8C 192999004463 | eBay
    VFD will be about $500. there will be other bits and pieces that will likely be another $500.
    I spent several hours today looking for an all new DC drive - no joy. I can see this DC motor has been rebuilt. if a drop in single phase DC drive is made, I'd look at that route.
    Got plenty of time to think before acting here, this is not a rush job.
    "Drop-in" is for artificial coffee, tea bags, and laser printer toner kits.
    Classical machinery is another animal.
    If what you have is as clean as you say, you can PROBABLY get it running for a few hours study time and as little as ZERO cash spend. Worst-case is seldom more than brushes and bearings, a broken wire, resistor or few, a relay only now and then ... and STILL rudely CHEAP for a(ny) MG.
    BEST of all? Once put back to rights? An MG can run a VERY long time before it again needs brushes.
    Total cost can be far less than your estimate for the VFD's motor alone .. even if exciter or generator were to need a rewind. Which is RARE. Very.
    Electrical guru "at present" or not?
    You learnt to drive a motor car and use machine tools and a whole lot more you weren't born knowing. We all have.
    It ain't as if you have to build the whole of electronics technology from scratch.
    An MG is "blacksmith grade simple", PM community has seen a lot and walked MANY folks through the needful steps.
    Already.
    You can DO this. It's even faster and less total work as well as cheaper.
    A VFD downgrade is NOT "simple drop in." It is only a different KIND of work and spend that makes one THINK it is.
    Annnnnd if you insist on it? You can still downgrade it to a VFD later.
    NB: I rather SUSPECT that the proven industrial-grade VFD the factory utilizes, present-day 10EE, costs a LOT more than "$500". There will be sound reasons for that. Plenty of them.
    Why not save the MONEY s well as the time.. to buy other stuff.. and have more time to use it?
