I'm almost to the point of installing the spindle motor and gearbox into my project 10EE. It's a 57 square dial but missing all the original WIAD components. After discussion with Monarch, they sold me a 5HP A/C motor that came from one of their rebuild cores. It's on a rectangle base plate that supports both the motor and the gearbox, it must have been from a later model. My lathe had a triangular base plate that had mounts for the motor but not the gear box. The newer base plate would not fit in the base, the hole in the bottom is to big.
Given the background info: I would like to hear options from your experience. Do you think I would have problems if I mounted the rectangle base plate to the triangular one? Belt length, gear box control etc...
thanks,
Jim
thanks,
Jim
