rimcanyon
- Sep 28, 2002
- Salinas, CA USA
I took some pictures of the guts of a 10ee 2500 RPM tachometer from a 1942 machine. The pictures show a few things that may not be obvious. The bezel is removable without removing the tach, if the glass is broken or the tach needs to be serviced. The glass is held in place betwen a pair of fiber gaskets, and the bezel wedges into the outside chrome trim piece that attaches to the tachometer. I imagine that there was a puller that could grip the outside of the bezel to remove it; this one was removed by prying a few times, the marks show.
The dial and needle have been removed, so the assembly that has the balance shaft and spring is visible and there are several pictures that show it. The rotating cup (aluminum) is attached to the balance shaft with a brass nut (looks like a small gear) at the center. There is a steel shim between the cup and the brass nut, which I assume would be all that needs to be replaced to convert this to a 4000 RPM tach (replaced by a smaller size shim, so that the rotating assembly would be less affected by the magnetic field). The cup is balanced (the three cuts show on the underside), so I assume the shim would need to be balanced as well, although it is not round (it has arms that bend up around the cup center support).
Below the balance shaft assembly is the magnet that is driven by the spindle (with the number 100 pencilled on it).
-Dave
-Dave
