rke[pler
- Feb 19, 2002
- Peralta, NM USA
Well, after using my lathe more and more I'm finding some of those little annoyances, and one has come to irritate me all too much. The MT2 taper in the tailstock quill is overground by about .010". No too much, but it makes some tools not fit at all and others require taking out the tang stop screws on the spindle for the taper to engage all the way in.
The best solution I've found to date is to hard chrome the taper, then have it ground back to specification. There's an unfortunate lack of local outfits to do either, so I figured that if I had to send it out I'd check with those that might have had it done before.
Monarch is sending me a quote for this, said that they hadn't done it for some time. I've priced out the plating and it was higher than I expected when they guessed at $150. The grinding is going to be expensive - expensive small wheel and excessive time on hard material. I've dropped email on a couple of outfits that appear to fix spindle tapers on the off chance that a MT2 tailstock quill wouldn't be too far from their regular job.
Anyone got comments? Maybe a spare quill (it might be cheaper to fit a different quill than to try and fix the taper in the old one).
