Results 1 to 4 of 4
10-17-2019, 10:21 PM #1
10EE tailstock lubrication dip-stick?
I've taken the tailstock apart on my 1943 10EE and am a bit confused about the lubrication.
On the top there is an oil hole and that appears to keep the tailstock screw and spindle lubed. OK.
Then there is a second hole on the bottom. It leads to a chamber, and from there a brass tube runs to one of the ways. I don't find a metering value so I presume it just drips at will.
Am I correct so far?
To the left of the bottom oil hole is another larger hole with something that looks like a mini dip-stick. (See image.) The hole it fits into is blind; I don't find any holes cross-drilled to it. It is like it is just a place to hold the dip-stock. What in the world is this for?
10-17-2019, 10:47 PM #2
Oil dauber for oiling the tip of a dead center.
rakort liked this post
10-18-2019, 10:41 AM #3
You can make a "white lead" ( if you can find it) slurry to go in that hole if you really want to be authentic .
. I think rkepler posted a a good pic pic of the dauber in question a few years ago. It's not hard to make a replica.
Mark999 liked this post
10-19-2019, 09:03 PM #4
I don't know why but it seems common to find 10EE's that still have their daubers.
I had a 43 round dial that had been around the block more than a few times and still had its dauber.
It's very unusual to find a South Bend lathe that still has one.
