10EE Taper Attachment Angle Adjustment Troubleshooting - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    Aug 2002
    Oregon
    97
    9
    Quote Originally Posted by labeeman View Post
    Mine does have a taper function
    Attachment 256151
    I've never used the taper function, but mine appears to be the same as labeeman's. Mine in a Newall DP700, two axis, carriage and cross slide. I am curious how the "touch"ing is done to maintain accuracy.
    Rick
  2. #22
    May 2003
    4,669
    357
    It has been awhile since I used the taper attachment, and yes there is a lash problem that either requires having the taper attachment travel a distance before the tool meets the work, or pulling back on the tool post by hand will get most lash out.
    Some years ago, someone here mentioned cutting from the backside of the part does this automatically, I remember cutting some short tapers in a collet like that.
  3. #23
    Dec 2017
    ALAND ISLANDS
    55
    8
    Does anyone have the instructions for using the taper attachment?
    Sent from my iPad using Tapatalk
  4. #24
    Aug 2002
    Oregon
    97
    9
    I have several versions. They are pretty basic and do not provide anything on troubleshooting it.
    I can scan and send them if you send me a PM with your email address. It will be a few days before I can get to doing it.
    Rick
  5. #25
    Feb 2002
    Peralta, NM USA
    5,720
    50
    498
    After grinding and rebuilding mine I set the taper on zero, mounted an indicator to the lathe bed and zeroed the slide to the bed using the eccentric bearings, setting them for the level of tightness that felt right. It's worked pretty well, I can usually set the swivel and it's pretty close the the angle I want on a cut.
  6. #26
    Mar 2016
    Louisiana
    397
    206
    70
    Here is a short video on using a Taper attachment.
