19 tpi
Results 1 to 10 of 10
Thread: 19 tpi
    Jun 2007
    Nevada
    529
    66
    Default 19 tpi
    I made this transposing gear for Daryl to cut 19 threads per inch. It is 57/60. The material is delrin. Much easier to deal with than steel for this application where it might be used 10 times in Daryl's entire machining career. For those who might think delrin isn't strong enough, a module 1 (25.4 Dp) gear can take upwards of 8 horsepower in a model helicopter, so the 16 Dp teeth here are plenty, plenty strong.
    The gear ratio for a 20 tpi setting is:
    24/60 times 60/(everything to the leadscrew) and that equals a carriage movement of 1/20 inches per thread. The 60 in the numerator
    and denominator is the 60 tooth idler.
    To increase the 1/20 inches to 1/19 inches multiply by 20/19. To keep both sides of the equation equal multiply the left side by 20/19
    24/60 * 60/(everything else) * 20/19 = 24/60 * 60/(everything else) * 60/57
    which reduces to 24/57 * 60/(everything else)
    So using a 57/60 idler will cut 19 TPI on a 20 TPI setting.
    It goes without saying that one needs to be very careful and concentrate with no distractions when playing around in the gearbox. If a nut is dropped into the bottom of the gearbox it will be a very unhappy day.
    Attached Thumbnails Attached Thumbnails img_0888-copy.jpg   img_0889-copy.jpg   img_0891-copy.jpg
  2. Likes Zap921, Ray Behner, daryl bane, DJ2 liked this post
  3. #2
    Oct 2018
    Ohio
    214
    187
    38
    Nice job, looks great!
    Mar 2002
    dallas,tx
    2,541
    587
    475
    Fantastic!! Many Thanks! Great info.
    Sep 2010
    Oklahoma City, OK
    4,690
    806
    1936
    Could this be done in a 100/127 ratio for a 12CK?
    May 2009
    Canandaigua, NY, USA
    2,932
    144
    1325
    Any time I need a change gear for my Logan, it gets made out of Delrin. They work great, last near to forever and are much nicer to the gear cutter.
  7. Likes Zap921 liked this post
  8. #6
    Mar 2011
    Geneva Illinois USA
    6,337
    2747
    2468
    And they are smooth and quiet running.
    Tom
  9. #7
    Jun 2007
    Nevada
    529
    66
    Conrad is being modest. I use a program he wrote to calculate 4 gear ratios for my hobber. His program calculates to 6 significant digits. It is a lifesaver for helical gears.
    John
  10. #8
    Jun 2007
    Nevada
    529
    66
    Cole, I am sure I could come up with a solution for just about any lathe for a metric gear. Send me pictures of your gear train and threading chart.
    John
  11. #9
    Jun 2007
    Nevada
    529
    66
    Daryl, here is the problem. You have the wrong Monarch lathe....
    Monarch Series 60 (61 also, I would assume?) factory Inch/Metric brochure
  12. Likes daryl bane liked this post
  13. #10
    Mar 2002
    dallas,tx
    2,541
    587
    475
    It was a huge surprise to me that my 59 EE could not cut 19tpi. And before your gear had to use my ...gasp. 25yr old Enco.
