1944 Round Dial Brushes for the Reliance VS drive
Results 1 to 3 of 3
    Jun 2021
    Washington
    238
    39
    53
    Default 1944 Round Dial Brushes for the Reliance VS drive
    Hey guys,
    I looked over my manual and couldn't find any info there.
    I need to replace the brushes for my Motor Generator setup. I took them down to the local motor shop and they told me that I have to order the brushes on line, and they dont stock them... plus they only wanted to help me out with them if I had them service the motor gen set for $900! For that price, I'd be looking really hard at just converting to a new 3Phase setup.
    Anyways I know I need knew brushes, and the lathe was running when I bought it, so I'm sure the motors will be fine after cleaning and fresh lube.
    Any chance you guys can help point me in the right direction for ordering new brushes? I have not had any luck finding a cross reference with the brush part numbers anywhere, but then again I dont exactly know where to look.Its been 20 years since I had a basic Electrical Engineering class... I was a plastics major after all. So I know enough to know I dont know anything about electric motors.
    The DC Motor is:
    Frame 14-T
    Serial number 827780
    3HP
    RPM 6900-2400
    12 AMp
    50 sdegree C 1HR duty
    Shunt Wound
    F/S 161-EQ-15
    Field Maps 1.5
    Rehostat Res 400 Ohms
    230 Volt Armature 115 V Fields.
    The 3 Phase AC to DC Generator is:
    220 V, 13.2 Amps
    440 Volts 6.6 Amps
    3 Phase, 60 cycles
    Frame 3 S
    115 Exciter Volts
    Serial Number 51 V 67
    The only info I could find on the Exciter, as there is no name plate attached is the following stamp:
    71718-2-RA
    459570
    Thanks Guys.
    Apr 2011
    Wisconsin
    528
    217
    121
    this is where you get brushes
    Parts | Monarch Lathes
  3. Likes GrantGunderson liked this post
    Virginia
    23,073
    7561
    13127
    Quote Originally Posted by GrantGunderson View Post
    Hey guys,
    The DC Motor is:
    Frame 14-T
    3HP
    RPM 6900-2400
    12 AMp
    Shunt Wound
    F/S 161-EQ-15
    Field Maps 1.5
    220 V, 13.2 Amps
    440 Volts 6.6 Amps
    3 Phase, 60 cycles
    Frame 3 S
    115 Exciter Volts
    71718-2-RA
    459570
    Thanks Guys.
    What Rakort said.
    "I suspect.." that Monarch 'of the present era' .. has Helwig Carbon make them up to the OEM spec. Periodically. In batches.
    Cheaper to buy what is already known to work properly ... than to try to re-discover what they have never NOT known?
    Seems so.
    All Monarch need is the serial number of your 10EE.
    Prices ain't half bad. And you get the RIGHT brushes!
    What's not to like about THAT?
  5. Likes GrantGunderson liked this post
