2 Monarch project lathes, 1964 10EE, 1944 12"CK
rabler
Cast Iron
May 25, 2020
Rural S.W. Indiana
I'm working on rebuilding a 1944 12" CK:
I've already replaced the original 1200RPM motor with a ABB/Baldor 3HP 1800RPM motor and a Teco L510 VFD with a rotary switch configured for 40Hz (1200RPM), 60Hz (1800 RPM) and 80Hz (2400RPM) to get original labeled speeds as well as 1.5x and 2x, as that machine had a stock maximum of 550RPM on the headstock. Had to fabricate a simple adapter to fit the smaller new motor in the right place. Home shop, so picked the 3HP as something feasible to power off a single phase 220V VFD, if I had realized at the time that I could have used a 10HP 3PH VFD to power a 5HP 3PH motor off of 220 single phase I would have gone that route.
If anyone wants the original 3HP motor, it still ran when I took it out but not in great shape. Local pickup from S.W. Indiana, $50.
I've taken apart the TA, replaced all the bearings, cleaned and repainted it.
Currently have the apron, cross slide, compound, and saddle disassembled, for cleaning, repainting and new bearings. Making new sleeves for the clutch handles as both were worn out (thanks to Keith Rucker's Youtube video's for some hints there as well as overall good motivation).
I'll post more pictures as I go.
And then yesterday I picked up a 1964 10EE, 20" bed, original 5HP motor and change gears and ELSR. That will be my next project when the 12" CK is done.
Over the years lathes evolved to be able to run at high speeds. Taking an old machine that runs at 500, and making it run 2000rpms, is a really bad idea because the machine is not designed to do that, it will fail rapidly.
Save the fast stuff for the ee.
My hendey has a top speed of 1k rpm, I wouldn't want to be in the same room if it was running twice that speed.
I was worried about the top speed, but I rarely run it over 590 rpm. Mostly 340 to 434 (think those are the numbers, or close)
Sent from my SM-N960U using Tapatalk
Not sure how you got 2000rpm, perhaps confusion between motor rpm and headstock/chuck rpm? Max I have it setup for is 2x original, so 1100rpm at the chuck. I expect I’ll be using the 1.5x setting mostly, so roughly 800rpm max, which is optimum for the 1800rpm motor. I believe the CYs of the era ran around
that with basically the same bearings, etc. I’m willing to push it that hard for home shop work, I’m not running production.
You will find plenty of help here as to KEEPING that nice DC motor and "feeding it" -
No matter WHAT kind of DC power source you have to work with - OEM or other - PM community hosts folks with expertise in sorting any of 'em. OR replacing any of 'em ... if need be.
Please don't downgrade THAT one to a VFD!
It's kind of embarrassing....
:D
I’m reading through PM’s 10EE threads greedily. Looks like a Parker 514c-32 is the way to go, ebay currently has a bunch from china, which I worry are knock-offs. Anyone have a reliable current source?
That said, IF you have ANY of the "OEM" Monarch DC Drive, even though older technology, it is generally more than good enough to restore what you already HAVE.
Each era of 10EE was put through plenty of testing and TUNING. So ALL of the OEM drives worked with the rest of their 10EE very well.
This one has a third party DC controller. You can see pics in metal4130's post in the for sale section if the moderators haven't yet deleted it. It currently only spins up to about 1000rpm. So I'm leaning toward replacing the third party stuff with, well, more common third party stuff, rather than trying to decipher why the current setup doesn't work. Hopefully a better chance of getting the ELSR integrated correctly that way.
Wonder how many Hamster-wheels on a common shaft would be needed so a 10EE could make chips?
Anybody up for training a thousand or so of the little buggers to wheel-trot at "route step, march!" .. so as to keep the driveline vibration down?
:D
I could probably find a barn cat or two to help with that endeavor. But the wife has horses, so why not shoot for a 10HP upgrade? :eek:
The thread Mark (everettengr) did is your guide, then. He integrated his OEM ELSR.
I had worked with him to duplicate my SSD drive settings, boost transformer power, add "ripple filter" for a 3 HP large-frame motor, not yet sure if the 6 HP rated (thermally) but only 16 A rated (Current max) SSD-514C-16 could run the 18+ Full Load Amp 5 HP motor of his "module" drive 10EE. The "right one" shudda been the SSD 514C-32 (32 Amp max)
The -16 had already proven good on a WiaD "small frame" 3 HP I had for test as is now in another member's 10EE. But that was close to the 12 FLA of the "large frame" Reliance.
Thanks thermite, I've found everettengr's thread and will be looking at that carefully. Should be an interesting project.
New folks are always reading these threads, and a quick explanation of the Electric Leadscrew Reverse could be helpful. The ELSR doesn't really electrically and magically reverse the leadscrew, all it really does is shut the spindle off with adjustable stops.
So, the magic really comes in with the original Monarch drive system, and this is how, when cutting threads, the halfnuts are left engaged the full time. The machine can be run faster then halfnuts can be engaged or dis engaged, this in multiple ways improves thread cutting. Many machines have mechanical systems for leadscrew reverse, the ee does it with the drives dynamic braking, making it possible to thread up to shoulders, or to the bottom of blind holes without needing relief grooves. Some replacement drives may not have good, or predictable braking.
Sounds like the synchro's are out in your transmission! You should learn how to cut screw threads, dont give me non of your crap about spring cuts on 50hp Niles lathes, you have never successfully cut screw threads ever, and it shows glaringly, so either learn how, or come up with a better lie.
Its certainly easier for me to cut threads then explain how, but maybe that's why I am paid to do it.
The Monarch drive system "when working properly" the spindle will stop in about 2 seconds regardless of speed by dynamically braking the spindle motor. The short stopping time is important for threading, I will try to explain how.
Remember when using the ELSR the threading dial is not used, the half nuts are locked in, the entire machine is reversed to return to the start of the thread.
Needed is a 14tpi thread to the bottom of a blind hole, no relief groove possible for the thread to stop in because of thin section.
So, for that thread, and diameter, I was comfortable running the machine at 250rpms in backgear. That is faster then I can work the half nut lever.
This is where you get your moneys worth, at 250rpms the spindle will stop in about one turn. Will your whooptidoo brand drive do that? Oh too bad.....
Really pretty amazing spindle control, so, when you hear the ELSR turn off the spindle, the switch drops out with a thunk, you have enough time to withdraw the tool, and fade out the thread in less then a turn like a pro, instead of a Mo Mo.
The stop time is critical when precision threading on an ee lathe, if it is a much longer spindle stop time it just doesn't work.
Often machinist don't cut a lot of screw threads, the ELSR is really good to have, but if you are cutting threads every day, its easy to just use a Travadial or a dro, and work the spindle switch manually. Often inch metric ee lathes were sold without ELSR when it was standard because it was not liked by some drivers.
My 1942 12CK has a max spindle speed of 1000
rpm. I don't know if there are any other differences besides the gearing, but it doesn't make sense to me that they would have intentionally built the slower version to a lower spec.
I recently bid on a '69 Pacemaker, 14x54, with a 3k spindle and 15HP. I'm not convinced I'd have the cajones to wind her all the way up.
Unfortunately, the bid got high enough that victory would have probably cost me a divorce and I did not win it.
I look forward to seeing your progress!
As far as the 1944 CK
Currently just about have the apron back together after completely taking it apart, cleaning out way too much crud in the bottom. Surprisingly the bijur pump had still been moving oil, after seeing all the crud in the bottom I was surprised it hadn't gummed up the intake. The apron has been repainted, many of the bearings replaced. Half nut and brass gear that engage the rack were in really good shape, wondering if they had been replaced at some point. The bushing on the cross slide drive gear was badly worn so I'll need to make sure the saddle oil line to that area, assuming there is one, is good.
Had to make new barrels around the clutch engagement shaft for both clutch levers.
I've also pulled the quick change gear box off and am working on disassembling that. It'll need new bearings too. I think this lathe may have sat unused for a few years, many of the bearing races have a small stained/pitted stripe, I presume from moisture combined with disuse.
Both the apron and especially the QCGB were loaded with chips, presumably someone using compressed air without realizing those two areas have openings that allow chips to get into the works.
The blue paint I ended up using on the CK isn't quite what I want for the whole lathe. Hazards of picking out paint colors online (computer screens aren't precisely color calibrated) but the pandemic limited my access to the local Sherman Williams store when I picked out the paint. Curb service only.
On the 10EE:
I'm working out the circuitry around the Parker 514c and 507, to incorporate the ELSR. I'm going to go with the potentiometer setting speed and the apron lever picking forward and reverse, to emulate the original functionality and my preferences. I hoping I can get the control for both drive units off of one potentiometer dial by using a 2-gang pot and some trim pots, and just switching between +10 and -10v reference for the pot for forward/reverse. This isn't going to be the cheapest approach as I'm completely scrapping the existing bastardized drive controllers, and putting in all the appropriate contactors, z-curve breakers, isolation transformers, etc to make this a complete rework. It has a factory coolant pump 1/10th HP 3PH that currently doesn't function, possibly just wiring, switch? I'm going to try to get that working with an inductive/capactive phase converter.
Before getting into the actual rewiring part on the 10EE, I'm probably going to fab up a metal base to temporarily lift it about 2ft off the ground. Just had minor knee surgery so getting down into the guts and doing a clean job is going to take more time than I'm willing to spend bent over that low.
Since the current electronics do turn the 5HP GE Kinamatic, just limited to about 1000 RPM, I'm going to get the new drive system working before I tackle pulling the old motor, checking the bearings and brushes, etc. But that is on the list, as I'm shooting for a complete rebuild. Going the the whole things is a really good way to actually understand all the aspects of this beast.
Removing Apron and QCGB
Some quick notes on disassembling the apron and quick change gear box on my '44 12" CK:
This is per my memory so may not be completely accurate.
To remove the apron, remove the shaft support from the right side of the bed. The plate on the apron side of the QCGB needs to be removed. The cover on the top right of the QCGB comes off to get to the gear mechanisms on the end of the shafts.
I was able to slide all but the threading screw out from the right side of the apron before pulling the apron.
Notice the slotted screw on the face of the saddle in the first picture. It holds an alignment pin from the saddle into the apron. There's another one on the other side. These have to come out in addition to the six cap screws on the top of the saddle to drop the apron.
Disassembling the apron was a bit of a challenge as I had to drive out the bearing cones to get many of the shafts out. Before taking the apron apart, take a minute to notice the interlock mechanism from the half nuts to the carriage feed engagement. Its the bar that goes across the back of the apron. Also pay attention to the layout of the copper oil lines. They're going to need to be moved and you'll want them back were they came from. I carefully bent mine out of the way, you could probably remove them completely with care(?) and save bending them.
The worm gear assembly going from the feed rod to the brass gear has it's own oil reserve and drain plug. I couldn't find replacements for the thrust bearings on either side of the worm except from Monarch at around $90 apiece.
This was one of the shafts for which I had to drive the bearing cone out to get clearance for the gear in the center to slide out the left side of the image. The other was the tapered bearings behind the manual carriage feed handwheel. The cones were a very tight fit.
The two clutches (carriage feed and cross slide feed) have a complex bearing/spring arrangement that is almost guaranteed to fall apart in the bottom of your apron when you try to take them out. This is where the CK diagrams from Monarch, or from vintagemachinery.org, are helpful.
I'll try to get around to posting on the QCGB removal and disassembly later.
(Note, I'm going to edit this over a couple of sittings. If you see this message it means it's not finished).
Removing the QCGB requires some prep. All of the apron control/drive shafts have to come out of the right side of the QCGB first. The bevel gear going to the clutch engagement lever needs to come off, it is held on to the shaft through the bed of the lathe by a taper pin. Hopefully you can get it turned to an angle where you can drive this pin out. The feed reversing rod (shown) engages in a toothed lever on a shaft. That lever needs to come out, as well as the inner lever that rides on a roller backed by a spring which provides a detent mechanism.
My model has run/stop buttons on the front of the QCGB that push rods going to switches on the back side. Those rodes slide out easily if you remove the run/stop plate.
On the clutch side, the gear train into the QCGB comes off, but the swing arm holding the gear train is attached to the QCGB and won't come apart until later. On the gear train side of the QCGB, my lathe had a small tab screwed into the lathe bed where the top of the QCGB met the lathe bed. Needed to take this out to get the QCGB off. Sorry, no picture.
Once these connections are out of the way there are four bolts, two on on the apron side and two on the gear train side, that hold the QCGB to the lathe bed. I rigged a strap to a gantry crane before removing them, it is heavy.
Here's what the innards of the QCGB look like. It basically has three compartments, the third is off the left side of this picture and is what seen in the picture above from the apron side. The compartment on the right has arm mentioned above that holds the drive train gears from the headstock, and behind that a shaft with gears couple to one of the shifters. On the left side is the cone gears and the dogs for the other selector. Behind that is the cone gears, and below is the shaft that the selector rides on.
This thing is a bit of a puzzle to disassemble. There are two bearing caps on the right (clutch) side of the picture. These caps cover taper bearings with the caps (and brass shims) loading the outer cone, so either the outer cone needs to come out the right side, or the bearing and shaft need to go inward. The inside of each of theses bearings has an oil retaining cap. I managed to drive out the bearing by getting a small brass punch in the key slot on the shaft so I could drive the bearing without damaging the oil cap. (I wasn't so lucky for all of these damn things).
For the shaft that the big gear arm rides on, underneath the left side of the center flange is a set screw,holding a large hub in that center flange. Inside the hub are taper bearings for the shaft on either side. Removing that set screw allows the hub through the center flange to be slid to the right. Once its far enough to the right, the right shaft can be removed.
Once the right side is out, the left side can be removed by removing the small gear and bear cap, driving out the bearing, and then removing the shaft toward the right (through the center compartment).
'44 CK QCGB bearing list
Apparently there is a time limit on how long you can go back and edit a post. So the previous post is going to retain the initial message :(
Here's a list of bearings as found in the guts of the QCGB. Be sure you're sitting down when you get the bill for these. Bearing shop thought I was rebuilding an airplane motor. It would take quite a few more HP to get this chunk of metal to fly.
Hoffman LS10 roller bearing
Timken-X 1775 taper with 1729-B outer cup (cup has a lip on it)
(Qty 5) X-Timken 1986 taper with 1931 outer cup
X-timken 1755 taper with x-timken 1729-B outer cup
X-timken 1985 taper with x-timken 1931 outer cup
Additionally, mine had a ND 3203 bearing in the center of the tumbler idle gear (#77 of the exploded parts diagram). This bearing isn't shown in the print and the oil mechanism was for the gear to spin directly on a small shaft which had an oil groove, so obviously it's a repair job. Unfortunately that oil mechanism didn't do a damn thing for the bearing so I'm going to try to get a -2RS bearing to go in there. The tumbler lever had two steel bushings to ride on a shaft, with quite a bit of wear/play despite the oil port. I'm replacing those bushings with bearing bronze. Both of those are provided oil with the "Oil tumbler at arrow" as marked on the feeds plate. Probably frequently overlooked.
Unfortunately that additional bearing caught me as soon as I started re-assembly. So that is stalled until I can get to the local bearing shop.
The cone gears all sit on a common key on their shaft. That key on mine was sheared at a couple points. Cheap to fix, before disassembly I was worried I had a bad gear or two due to some weird noises but things seemed to move appropriately. Since those cone gears engage with the above tumbler idler gear, the sheared key may coincide with additional bearing? Thankfully all of the gears are in good shape except for one face on the large compound gear. Looks like the selector wasn't aligning quite right. Gear appears to still be serviceable but hopefully I can improve the alignment.
There are a quite a few pressed-in metal caps ("bearing caps") in the diagram. Obviously intended to retain oil around the bearings. Notches are cut in these to line up with the oil ports drilled in the casting, so they'll need to be put in with those notches lined back up with those oil ports. While many of those cups are center-bored to allow the appropriate shaft through, two of them at the ends are solid. I ended up mangling the two solid ones removing them, as I couldn't see how get them out without damage. Have to find or make suitable replacements.
On second thought those bushings were probably steel sleeves for a reason. The idler lever slides on a shaft with a captive gear keyed to that shaft. Those steel bushings need to slide the key too. I’ll tahe a closer look tomorrow but I think there may be some sound reasoning from the Monarch designers.
That gear has a integral key. Which makes sense. So I don’t see any reason not to go with the bearing bronze.
Here is a picture of the tumbler lever, geared shaft, and idler gear.
Note the two slots on the top of the lever along either side of the gears. This is what you want to get oil into with the “oil tumbler at arrow” noted on the feeds and thread pitch plate. Thought that might be of interest to anyone with a similar Monarch that hasn’t seen the inside of the gear box. Since this provides oil to both gears and to the bushings that slide along that shaft, it is something that doesn’t do well without regular oiling.
Just a random update: the 1944 Monarch CK is getting closer to complete. Apron and quick change gearbox have had bearings replaced. Only major thing left is to go through the tailstock completely.
