3D printed parts for me 1942 10ee
Results 1 to 8 of 8
    Aug 2005
    Toronto
    5,424
    3626
    4237
    Default 3D printed parts for me 1942 10ee
    hehe, probably seems a little blasphemous, but it worked well. Part of my effort to get my '42 round dial going. A VFD was installed driving a 5 hp motor mated with the 2sp back gear (The lathe was acquired with only the back gear box, cut off from the original motor). I wanted to use the machine's original controls so came up with this as way to mount a potentiometer and drive with the chain from the speed control knob. There's an adjustable brake in it (with a brass bushing) so I can create some friction so it has the right feel and doesn't move after setting. More photos on my web site.....that is also a work in progress 3D plastic parts for the 10ee - Metallum
    Oct 2012
    335
    125
    151
    Screw blasphemy. You use whatever tools are available to you to make it the way you want it.
    I think it's a great use of 3D printing, a good design, and good execution.
    nice work.
  3. Likes Mcgyver liked this post
    Apr 2005
    Colorful Colorado
    1,011
    33
    58
    You should add a Monarch logo next time
  5. Likes Mcgyver, TheOldCar liked this post
  6. #4
    May 2020
    Florida
    18
    Much nicer than the hack job I did with OEM parts... Don
  7. #5
    Virginia
    15,854
    7561
    10679
    Quote Originally Posted by Mcgyver View Post
    .. came up with this as way to mount a potentiometer and drive with the chain from the speed control knob.
    That's all really impressive work!
    Thanks for sharing the 3-D application to solve a "legacy" challenge, not just cleansheet, new product, or bleeding edge.
    Kudos aside...
    Why not simply couple a bog-standard sub $15 Bournes or similar 5-turn potentiometer directly to the control shaft?
    An ignorant "O" ring or an adjustable faucet-stem "packing gland" robbed off the plumbing supplies blister-pak wall is all you would need for friction to prevent it creeping under running vibration.
  8. #6
    Apr 2011
    Florida
    97
    52
    I like this. Have you shared the files to thingverse yet so others may follow?
  9. #7
    Aug 2005
    Toronto
    5,424
    3626
    4237
    thanks, gladly to share with members here and I may put it on my website.
  10. #8
    Sep 2016
    Missouri
    906
    796
    281
    3D could be used a lot more in aplications like that. It looks great.
    The other part of the speed control back gear shifter is on ebay. The whole shaft from knob and handle to the shaft supports and the sprocket at $129.00. 0 bids 5 days left
    If anyone needs one.
    Monarch 10EE Lathe Speed Control Assembly
