Annotated List of Links to Monarch Patents (and to Some Non-Monarch Patents)
Results 1 to 14 of 14
    Dec 2002
    Monterey Bay, California
    10,248
    28
    223
    Post
    List, including patent titles (and remarks) ...
    http://www.pat2pdf.org/patents/pat1596700.pdf Clutch Actuating Device For Lathes
    http://www.pat2pdf.org/patents/pat1636028.pdf Lathe
    http://www.pat2pdf.org/patents/pat1642863.pdf Headstock For Lathe
    http://www.pat2pdf.org/patents/pat1686743.pdf Carriage Stop Mechanism For Lathes
    http://www.pat2pdf.org/patents/pat1750555.pdf Geared Headstock For Lathes
    http://www.pat2pdf.org/patents/pat1929269.pdf Apparatus For Automatic Form Turning Lathes
    http://www.pat2pdf.org/patents/pat1929270.pdf Machine Tool
    http://www.pat2pdf.org/patents/pat1931157.pdf Machine Tool
    http://www.pat2pdf.org/patents/pat1935007.pdf Machine Tool
    http://www.pat2pdf.org/patents/pat1937400.pdf Machine Tool
    http://www.pat2pdf.org/patents/pat2027568.pdf Lathe
    http://www.pat2pdf.org/patents/pat2039876.pdf Automatic Lathe
    http://www.pat2pdf.org/patents/pat2050746.pdf Machine Tool
    http://www.pat2pdf.org/patents/pat2051127.pdf Universal Lathe
    http://www.pat2pdf.org/patents/pat2052441.pdf Apparatus For Controlling the Operation of Tools
    http://www.pat2pdf.org/patents/pat2055227.pdf Motor Automatic Lathe
    http://www.pat2pdf.org/patents/pat2086153.pdf Apparatus For Control Of Machine Tools
    http://www.pat2pdf.org/patents/pat2105962.pdf Diameter Gauging Apparatus
    http://www.pat2pdf.org/patents/pat2138811.pdf Surface Hardening Lathe Bed
    http://www.pat2pdf.org/patents/pat2140949.pdf Apparatus For Turning Complex Workpieces
    http://www.pat2pdf.org/patents/pat2143255.pdf Lathe
    http://www.pat2pdf.org/patents/pat2143258.pdf Cam Making Machine
    http://www.pat2pdf.org/patents/pat2154947.pdf Hardening Of Metal Surfaces
    http://www.pat2pdf.org/patents/pat2157948.pdf Hardening Of Metal Surfaces
    http://www.pat2pdf.org/patents/pat2176700.pdf Telescopic Taper Attachment
    http://www.pat2pdf.org/patents/pat2184377.pdf Taper Forming Machine
    http://www.pat2pdf.org/patents/pat2184684.pdf Form Producing Machine
    http://www.pat2pdf.org/patents/pat2208319.pdf Lathe
    http://www.pat2pdf.org/patents/pat2259472.pdf Duplicator For Machine Tools
    http://www.pat2pdf.org/patents/pat2299677.pdf Taper Attachment Construction
    http://www.pat2pdf.org/patents/pat2309298.pdf Taper Attachment Construction
    http://www.pat2pdf.org/patents/pat2309299.pdf Method Of And Apparatus For Correcting The Lead Error Of Screw Threads
    http://www.pat2pdf.org/patents/pat2311203.pdf Taper Attachment Construction
    http://www.pat2pdf.org/patents/pat2325733.pdf Rapid Traverse Mechanism For Lathes
    http://www.pat2pdf.org/patents/pat2351649.pdf Method And Apparatus For Controlling The Operation Of Lathes
    http://www.pat2pdf.org/patents/pat2372426.pdf Duplicator For Machine Tools
    http://www.pat2pdf.org/patents/pat2372427.pdf Machine Tool Control
    http://www.pat2pdf.org/patents/pat2374322.pdf Lathe
    http://www.pat2pdf.org/patents/pat2377305.pdf Gear Change Mechanism For Lathes (10EE Round Dial Gearbox)
    http://www.pat2pdf.org/patents/pat2378001.pdf Flame Hardening Torch
    http://www.pat2pdf.org/patents/pat2378890.pdf Surface Hardening Metal Areas Of Limited Size
    http://www.pat2pdf.org/patents/pat2381422.pdf Sensitive Precision Lathe (10EE Round Dial Machine, Itself, Complete)
    http://www.pat2pdf.org/patents/pat2389757.pdf Apparatus For Operating Lathes
    http://www.pat2pdf.org/patents/pat2399806.pdf Machine Tool Control
    http://www.pat2pdf.org/patents/pat2412957.pdf Machine Tool Control
    http://www.pat2pdf.org/patents/pat2422681.pdf Machine Tool Control
    http://www.pat2pdf.org/patents/pat2434853.pdf Machine Tool Control
    http://www.pat2pdf.org/patents/pat2436373.pdf Machine Tool Control
    http://www.pat2pdf.org/patents/pat2441915.pdf Grooving Machine
    http://www.pat2pdf.org/patents/pat2450788.pdf Lathe Attachment
    http://www.pat2pdf.org/patents/pat2475326.pdf Control System
    http://www.pat2pdf.org/patents/pat2486097.pdf Control System
    http://www.pat2pdf.org/patents/pat2491403.pdf Indicator And Control Means For Lead Screw Correction
    http://www.pat2pdf.org/patents/pat2492251.pdf Lead Screw Variator
    http://www.pat2pdf.org/patents/pat2495312.pdf Power Unit For Machine Tools
    http://www.pat2pdf.org/patents/pat2512008.pdf Apparatus For Operating Lathes
    http://www.pat2pdf.org/patents/pat2526361.pdf Control Valve For Servomotors
    http://www.pat2pdf.org/patents/pat2540573.pdf Power Actuated Gear Shifter
    http://www.pat2pdf.org/patents/pat2540586.pdf Tailstock Carriage And Clamping Means
    http://www.pat2pdf.org/patents/pat2546692.pdf Control System
    http://www.pat2pdf.org/patents/pat2549971.pdf Control System
    http://www.pat2pdf.org/patents/pat2561724.pdf Apparatus For Operating Lathes
    http://www.pat2pdf.org/patents/pat2585215.pdf Power Unit
    http://www.pat2pdf.org/patents/pat2585216.pdf Unitary Mechanism For Performing Multiple Simultaneous And Successive Operations
    http://www.pat2pdf.org/patents/pat2585217.pdf Automatic Lathe
    http://www.pat2pdf.org/patents/pat2587312.pdf Turret Lathe
    http://www.pat2pdf.org/patents/pat2600988.pdf Constant Surface Speed Lathe (Ward-Leonard Drive Implementation, Probably 13EE)
    http://www.pat2pdf.org/patents/pat2608449.pdf Slide Bearing Weight Compensator
    http://www.pat2pdf.org/patents/pat2608896.pdf Pattern Tracer Assembly
    http://www.pat2pdf.org/patents/pat2608897.pdf Tool Slide
    http://www.pat2pdf.org/patents/pat2609524.pdf Electric Control System (10EE WiaD)
    http://www.pat2pdf.org/patents/pat2627065.pdf Burglar Alarm Box (NOT Monarch)
    http://www.pat2pdf.org/patents/pat2630135.pdf Fluid Distributing Value
    http://www.pat2pdf.org/patents/pat2634644.pdf Machine Tool Control
    http://www.pat2pdf.org/patents/pat2636579.pdf Tailstock Spindle Clamping Device
    http://www.pat2pdf.org/patents/pat2656589.pdf Semiautomatic Turret Lathe
    http://www.pat2pdf.org/patents/pat2720129.pdf Machine Tool For Automatic Cycling
    http://www.pat2pdf.org/patents/pat2737073.pdf Tailstock Actuating Device
    http://www.pat2pdf.org/patents/pat2737620.pdf Motor Control Circuit
    http://www.pat2pdf.org/patents/pat2755135.pdf Mist Lubricator
    http://www.pat2pdf.org/patents/pat2771807.pdf Tool Holder
    http://www.pat2pdf.org/patents/pat2777350.pdf Machine Tool Control Apparatus
    http://www.pat2pdf.org/patents/pat2781684.pdf Dual Automatic Cycle Machine
    http://www.pat2pdf.org/patents/pat2782651.pdf Hydraulic Jogger
    http://www.pat2pdf.org/patents/pat2782802.pdf Hydraulic Control System
    http://www.pat2pdf.org/patents/pat2782891.pdf Safety Controls
    http://www.pat2pdf.org/patents/pat2791885.pdf Hydraulic Tracer Control
    http://www.pat2pdf.org/patents/pat2814007.pdf Automatic Cycle Machine Tool
    http://www.pat2pdf.org/patents/pat2822072.pdf Device For Engaging Driving And Driven Members
    http://www.pat2pdf.org/patents/pat2825307.pdf Hydraulic Control System
    http://www.pat2pdf.org/patents/pat2864046.pdf Electrical Control System
    http://www.pat2pdf.org/patents/pat2864047.pdf Motor Control System (Scaled-up, Three-phase Version of WiaD, Probably EE1000)
    http://www.pat2pdf.org/patents/pat2871886.pdf Manifold
    http://www.pat2pdf.org/patents/pat2871887.pdf Manifolding
    http://www.pat2pdf.org/patents/pat2877655.pdf Hydraulic Control For Gear Transmissions
    http://www.pat2pdf.org/patents/pat2878704.pdf Control System
    http://www.pat2pdf.org/patents/pat2898891.pdf Hydraulic Flow Control
    http://www.pat2pdf.org/patents/pat2929274.pdf Hydraulic Control System
    http://www.pat2pdf.org/patents/pat2951342.pdf Electro-Hydraulic Servo System
    http://www.pat2pdf.org/patents/pat2972868.pdf Machine Tool Slide Control
    http://www.pat2pdf.org/patents/pat3017863.pdf Electrical Control System
    http://www.pat2pdf.org/patents/pat3024610.pdf Electrical Control System
    http://www.pat2pdf.org/patents/pat3036361.pdf Tool
    http://www.pat2pdf.org/patents/pat3053583.pdf Air Bearing
    http://www.pat2pdf.org/patents/pat3103827.pdf Dual Operator For Slides (1/1000 + 1/10000 Cross Slide)
    http://www.pat2pdf.org/patents/pat3122310.pdf Programmer
    http://www.pat2pdf.org/patents/pat3273023.pdf Selector Circuit
    http://www.pat2pdf.org/patents/pat3316629.pdf Machine Tool Tool Changer
    http://www.pat2pdf.org/patents/pat3375472.pdf Broadband Structure For Waveguide Hybrid Tee's (NOT Monarch)
    http://www.pat2pdf.org/patents/pat3375742.pdf Turret Mechanism
    http://www.pat2pdf.org/patents/pat3406924.pdf Apparatus For Winding Coils Of Metal Strip Material
    http://www.pat2pdf.org/patents/pat3414019.pdf Electro-Fluid Control System
    http://www.pat2pdf.org/patents/pat3466971.pdf Tool Holder
    http://www.pat2pdf.org/patents/pat3709377.pdf Tool Changer
    http://www.pat2pdf.org/patents/pat3711212.pdf Travel Limit Mechanism And Method
    http://www.pat2pdf.org/patents/pat3813745.pdf Dual Turret Lathe
    http://www.pat2pdf.org/patents/pat3934836.pdf Mandrel Assembly
    http://www.pat2pdf.org/patents/pat3999665.pdf Method And Apparatus For Handling A Coil
    http://www.pat2pdf.org/patents/pat4075753.pdf Plural Slide Machine
    http://www.pat2pdf.org/patents/pat4122597.pdf Tool Utilization Mechanism
    http://www.pat2pdf.org/patents/pat4296633.pdf Device For Temperature Measurement (NOT Monarch)
    http://www.pat2pdf.org/patents/pat4300418.pdf Tool Turret Mechanism
    http://www.pat2pdf.org/patents/pat4347723.pdf Method And Apparatus For Tensioning Metallic Strips On A Slitting Line
    http://www.pat2pdf.org/patents/pat4587822.pdf Tension Leveling Apparatus
    http://www.pat2pdf.org/patents/pat4604810.pdf Post Process Diameter Gage
    http://www.pat2pdf.org/patents/pat4635458.pdf Leveling Apparatus
    http://www.pat2pdf.org/patents/pat4736512.pdf Tool And Work Changer Assembly
    http://www.pat2pdf.org/patents/pat4765169.pdf Method Of Tension Leveling Nonhomogeneous Metal Sheet
    http://www.pat2pdf.org/patents/pat4794773.pdf Method Of Measuring Camber
    http://www.pat2pdf.org/patents/pat4801102.pdf Method Of Manufacturing Coated Rolls
    http://www.pat2pdf.org/patents/pat4827801.pdf Offset Indexable Fixture
    http://www.pat2pdf.org/patents/pat4856153.pdf Spindle Mechanism
    http://www.pat2pdf.org/patents/pat5007151.pdf Machine Tool Turret
    http://www.pat2pdf.org/patents/pat5033340.pdf Apparatus And Method For Tool Vibration Damping
    http://www.pat2pdf.org/patents/pat5088182.pdf Turret Changer
  2. Likes becomingguru liked this post
  3. #2
    Oct 2004
    Illinois
    976
    163
    148
    Post
    Thanks for taking the time to post this. It will be a great help!
    John
    Dec 2002
    10,248
    28
    223
    Post
    Thanks for your most kind comment.
    From the patent title, one can see, in a general way, the changes in focus of Monarch Machine Tool over time: from engine lathes, to tracers, to materials science (first flame-hardening processes and materials; then spot-hardening), to super-precision lathes, to automatic lathes, to hydraulically controlled large lathes, to automated turning centers other than lathes, to ancillary production equipment.
    Oct 2004
    Illinois
    976
    163
    148
    Post
    Just bragging a very little, but I actually made the drawing for Patent 5033340 (second to last).
    The last patent on this list was the turret changer and turret for Monarch's Ultra Center. The was truly a revolutionary machine that was plagued by poor reliability. I did a lot design of work on this machine. With the turret changer one could switch from making parts with a bar feeder to chuck work in five minutes. This included: removing the remaining slug from the spindle; changing 24 sets of tools (12 tool in right and left hand turrets); chuck jaws on the right and left chucks; loading a new chuck slug; and then loading a new program. It was really a sight to see. Monarch had a video showing the change over.
    Early machines were rushed to market without full testing a bugging. After the first 30 or so nearly all the bugs were solved and the machine was averaging about 95% up time verse the below 80% for the earlier production machines. But by that time, most of Monarch's dealers were scared to sell the Ultra-Center. Only with its supper high productivity gains did customers buy the machine. Monarch made about 80 Ultra-Centers the seven years it was in production. Fourteen heavily modified Ultra-centers saw their way into an automated turning line at American Axle. There was three lines having four Ultra-Centers and another having two. The last of these was shipped about the time the Sidney division was sold.
  6. Likes JHOLLAND1 liked this post
  7. #5
    Dec 2002
    10,248
    28
    223
    Post
    "Just bragging a very little, but I actually made the drawing for Patent 5033340 (second to last) ..."
    Kinda strange when the one product a company is best known for, and is also probably the most revered for as well, was designed nearly seventy years ago.
  8. #6
    Dec 2002
    10,248
    28
    223
    Post
    "http://www.pat2pdf.org/patents/pat2600988.pdf Constant Surface Speed Lathe (Ward-Leonard Drive Implementation)"
    This is the 13"EE.
    You will note that Monarch Tool patented the conceptually simpler phase-controlled field regulator in this patent before it patented the conceptually more complex phase-controlled armature regulator, which necessarily included the phase-controlled field regulator, in the later 10"EE WiaD patent.
    "http://www.pat2pdf.org/patents/pat2864047.pdf Motor Control System (Scaled-up, Three-phase Version of WiaD, Perhaps EE1000)"
    This is indeed the EE1000.
    This includes the single-phase constant surface speed phase-controlled field regulator, patented much earlier, plus a three-phase phase-controlled armature regulator not unlike the single-phase WiaD armature regulator, except the I-R compensation is in the B-phase alone (L3), rather than in the A and C phases (L1 and L2) as in the WiaD patent.
  9. #7
    Jul 2004
    Houston, TX USA
    31,505
    Post
    Just a note - those links seem no longer to work.
    "File removed from cache"
    John
  10. #8
    Dec 2002
    10,248
    28
    223
    Post
    "Just a note - those links seem no longer to work."
    Pat2pdf.org is a free service [ * ] which necessarily must conserve its resources.
    Consequently, requests for patent documents are "cached", and the cache is "replaced", probably on an LFR (least frequently referenced) basis.
    If a link appears to be "broken", rest assured it is not. I have individually tested these URLs, and the patents are indeed there.
    Initiate the process again, and the patent will, again, become cached.
    [ * ] There is another service, pat2pdf.com, which is not free.
  11. #9
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,169
    451
    1088
    Post
    Looks like you take the number, in the case of the first link, 1596700 and enter it into the text box below (on the 404 error page).
    I looked over the first one, appears to be the apron clutches on the C_ series. An interesting aside, they use "alined" to mean "aligned" (I think!) in several places.
  12. #10
    Nov 2005
    Maryland
    8,201
    746
    1107
    Post
    As Peter said, pat2pdf.org caches the search results, but only for a brief time. I think it's on the order of a few days, but don't quote me.
    Just enter the patent number in the search box and it will generate a new copy for you. I use this site all the time, and it's great.
    Leigh
  13. #11
    Nov 2005
    Maryland
    8,201
    746
    1107
    Post
    Since the hyperlinks to pat2pdf.org do not work, I took the liberty of editing Peter's list to extract just the actual patent number plus description. This may make it easier to cut and paste on the pat2pdf website. I also moved the three patents labeled "NOT Monarch" to the end of the list. This list should match Peter's exactly.
    1596700 Clutch Actuating Device For Lathes
    1636028 Lathe
    1642863 Headstock For Lathe
    1686743 Carriage Stop Mechanism For Lathes
    1750555 Geared Headstock For Lathes
    1929269 Apparatus For Automatic Form Turning Lathes
    1929270 Machine Tool
    1931157 Machine Tool
    1935007 Machine Tool
    1937400 Machine Tool
    2027568 Lathe
    2039876 Automatic Lathe
    2050746 Machine Tool
    2051127 Universal Lathe
    2052441 Apparatus For Controlling the Operation of Tools
    2055227 Motor Automatic Lathe
    2086153 Apparatus For Control Of Machine Tools
    2105962 Diameter Gauging Apparatus
    2138811 Surface Hardening Lathe Bed
    2140949 Apparatus For Turning Complex Workpieces
    2143255 Lathe
    2143258 Cam Making Machine
    2154947 Hardening Of Metal Surfaces
    2157948 Hardening Of Metal Surfaces
    2176700 Telescopic Taper Attachment
    2184377 Taper Forming Machine
    2184684 Form Producing Machine
    2208319 Lathe
    2259472 Duplicator For Machine Tools
    2299677 Taper Attachment Construction
    2309298 Taper Attachment Construction
    2309299 Method Of And Apparatus For Correcting The Lead Error Of Screw Threads
    2311203 Taper Attachment Construction
    2325733 Rapid Traverse Mechanism For Lathes
    2351649 Method And Apparatus For Controlling The Operation Of Lathes
    2372426 Duplicator For Machine Tools
    2372427 Machine Tool Control
    2374322 Lathe
    2377305 Gear Change Mechanism For Lathes (10EE Round Dial Gearbox)
    2378001 Flame Hardening Torch
    2378890 Surface Hardening Metal Areas Of Limited Size
    2381422 Sensitive Precision Lathe (10EE Round Dial Machine, Itself, Complete)
    2389757 Apparatus For Operating Lathes
    2399806 Machine Tool Control
    2412957 Machine Tool Control
    2422681 Machine Tool Control
    2434853 Machine Tool Control
    2436373 Machine Tool Control
    2441915 Grooving Machine
    2450788 Lathe Attachment
    2475326 Control System
    2486097 Control System
    2491403 Indicator And Control Means For Lead Screw Correction
    2492251 Lead Screw Variator
    2495312 Power Unit For Machine Tools
    2512008 Apparatus For Operating Lathes
    2526361 Control Valve For Servomotors
    2540573 Power Actuated Gear Shifter
    2540586 Tailstock Carriage And Clamping Means
    2546692 Control System
    2549971 Control System
    2561724 Apparatus For Operating Lathes
    2585215 Power Unit
    2585216 Unitary Mechanism For Performing Multiple Simultaneous And Successive Operations
    2585217 Automatic Lathe
    2587312 Turret Lathe
    2600988 Constant Surface Speed Lathe (Ward-Leonard Drive Implementation)
    2608449 Slide Bearing Weight Compensator
    2608896 Pattern Tracer Assembly
    2608897 Tool Slide
    2609524 Electric Control System (10EE WiaD)
    2630135 Fluid Distributing Value
    2634644 Machine Tool Control
    2636579 Tailstock Spindle Clamping Device
    2656589 Semiautomatic Turret Lathe
    2720129 Machine Tool For Automatic Cycling
    2737073 Tailstock Actuating Device
    2737620 Motor Control Circuit
    2755135 Mist Lubricator
    2771807 Tool Holder
    2777350 Machine Tool Control Apparatus
    2781684 Dual Automatic Cycle Machine
    2782651 Hydraulic Jogger
    2782802 Hydraulic Control System
    2782891 Safety Controls
    2791885 Hydraulic Tracer Control
    2814007 Automatic Cycle Machine Tool
    2822072 Device For Engaging Driving And Driven Members
    2825307 Hydraulic Control System
    2864046 Electrical Control System
    2864047 Motor Control System (Scaled-up, Three-phase Version of WiaD, Perhaps EE1000)
    2871886 Manifold
    2871887 Manifolding
    2877655 Hydraulic Control For Gear Transmissions
    2878704 Control System
    2898891 Hydraulic Flow Control
    2929274 Hydraulic Control System
    2951342 Electro-Hydraulic Servo System
    2972868 Machine Tool Slide Control
    3017863 Electrical Control System
    3024610 Electrical Control System
    3036361 Tool
    3053583 Air Bearing
    3103827 Dual Operator For Slides (1/1000 + 1/10000 Cross Slide)
    3122310 Programmer
    3273023 Selector Circuit
    3316629 Machine Tool Tool Changer
    3375742 Turret Mechanism
    3406924 Apparatus For Winding Coils Of Metal Strip Material
    3414019 Electro-Fluid Control System
    3466971 Tool Holder
    3709377 Tool Changer
    3711212 Travel Limit Mechanism And Method
    3813745 Dual Turret Lathe
    3934836 Mandrel Assembly
    3999665 Method And Apparatus For Handling A Coil
    4075753 Plural Slide Machine
    4122597 Tool Utilization Mechanism
    4300418 Tool Turret Mechanism
    4347723 Method And Apparatus For Tensioning Metallic Strips On A Slitting Line
    4587822 Tension Leveling Apparatus
    4604810 Post Process Diameter Gage
    4635458 Leveling Apparatus
    4736512 Tool And Work Changer Assembly
    4765169 Method Of Tension Leveling Nonhomogeneous Metal Sheet
    4794773 Method Of Measuring Camber
    4801102 Method Of Manufacturing Coated Rolls
    4827801 Offset Indexable Fixture
    4856153 Spindle Mechanism
    5007151 Machine Tool Turret
    5033340 Apparatus And Method For Tool Vibration Damping
    5088182 Turret Changer
    2627065 Burglar Alarm Box (NOT Monarch)
    3375472 Broadband Structure For Waveguide Hybrid Tee's (NOT Monarch)
    4296633 Device For Temperature Measurement (NOT Monarch)
    Leigh
  14. #12
    Dec 2002
    10,248
    28
    223
    Post
    At least the cached page URL is consistent, and as long as the cached page is active, any number of people can download the patent using the same URL.
    Within several days that page will ideed be "replaced", and you'll get a 404 on it.
    But cause that page to be reloaded, and it will again appear with the same URL.
    A much better system than, say, Yahoo! where the page's change names all the time.
  15. #13
    Dec 2002
    10,248
    28
    223
    In all probability, not all (if any) of the above Monarch Tool patents are presently "cached" by pat2pdf.org.
    To "cache" all of them, thereby refreshing all of the hyperlinks, above, for a day or so, copy the following text to your clipboard, point your browser to ...
    ... paste your clipboard to the date entry area, and press enter.
    If you need only one or a few patents, edit the text, below, in your clipboard, then paste the edited list, as described, above.
    Text:
    1596700; 1636028; 1642863; 1686743; 1750555; 1929269; 1929270; 1931157; 2051127; 2052441; 2055227; 2086153; 2105962; 2138811; 2140949; 2143255; 2143258; 2154947; 2157948; 2176700; 2184377; 2184684; 2208319; 2259472; 2299677; 2309298; 2309299; 2311203; 2325733; 2351649; 2372426; 2372427; 2374322; 2377305; 2378001; 2378890; 2381422; 2389757; 2399806; 2412957; 2422681; 2434853; 2436373; 2441915; 2450788; 2475326; 2486097; 2491403; 2492251; 2495312; 2512008; 2526361; 2540573; 2540586; 2546692; 2549971; 2561724; 2585215; 2585216; 2585217; 2587312; 2600988; 2608449; 2608896; 2608897; 2609524; 2630135; 2634644; 2636579; 2656589; 2720129; 2737073; 2737620; 2755135; 2771807; 2777350; 2781684; 2782651; 2782802; 2782891; 2791885; 2814007; 2822072; 2825307; 2864046; 2864047; 2871886; 2871887; 2877655; 2878704; 2898891; 2929274; 2951342; 2972868; 3017863; 3024610; 3036361; 3053583; 3103827; 3122310; 3273023; 3316629; 3375742; 3406924; 3414019; 3466971; 3711212; 3813745; 3934836; 3999665; 4075753; 4122597; 4300418; 4347723; 4587822; 4604810; 4635458; 4736512; 4765169; 4794773; 4801102; 4827801; 4856153; 5007151; 5033340; 5088182
  16. #14
    Dec 2002
    10,248
    28
    223
    FWIW ...
    Caching at pat2pdf.org ordinarily lasts less than one day in a low-demand situation. In a high-demand situation, caching could be substantially less than one day.
    Not withstanding that observed fact, users are encouraged to select only those patents which are of immediate interest to them.
    Copy all to clipboard.
    Edit (delete most).
    Copy remaining from clipboard.
    Invoke pat2pdf.org.
    Paste.
    Get (selected) patents.
