Anyone have a 10ee stop rod for sale?
Likes Likes:  0
Results 1 to 20 of 20
    Mar 2012
    Las Vegas
    842
    15
    107
    Default Anyone have a 10ee stop rod for sale?
    I need a carriage stop rod for a 1947 10ee on which I am working. Square Dial. Anyone have one they want to sell?
    Rich
    Send me a PM.
    Sep 2002
    Salinas, CA USA
    4,840
    540
    447
    Quote Originally Posted by lectrician1 View Post
    Rich
    Send me a PM.
    If you can find one for a larger Monarch it would probably work; i.e. the only difference is the length, diameter of the handle and bar and the knurling are the same.
    Sep 2005
    Northern California
    1,126
    189
    Rich
    What do the lads in Sidney Ohio charge for a stop rod?
    Mar 2012
    Las Vegas
    842
    15
    107
    i didn't call them yet
    Sep 2005
    Northern California
    1,126
    189
    Hard to tell, it might be reasonable $, and then again maybe not. That said if we had a DWG, and a stick of O-1, the rest is EZ.
    Sep 2002
    Salinas, CA USA
    4,840
    540
    447
    Quote Originally Posted by Cyclotronguy View Post
    The design is very simple: the shaft is ¾", knurled 4" at the end. The knob is 1.237" dia. and 1.25" long. The inside corner of the knob has a .125" bevel, the outside corner has a 3/16" bevel, the knurled end has a 1/16" bevel. The knob is a press fit. On the 1940 KOBar, the knurling is a diamond pattern, .070" pitch. On the 1950's bar the knurling is a straight pattern with a .040" pitch. OAL is 26 5/16". The knurling does not have sharp corners, i.e. it is turned down to .755" after knurling.
    Sep 2002
    Salinas, CA USA
    4,840
    540
    447
    One more detail on the construction of the knock out bar: the diameter of the shaft where the knob is pressed on is .625". If that is not clear, here is a photo:
    Mar 2012
    Las Vegas
    842
    15
    107
    I’m looking for the rod that goes through the headstock and stops the carriage. The rod that has detents every half inch
    Sep 2005
    Northern California
    1,126
    189
    Again a pretty simple part, we just need a "print". And that said the folks at Monarch are pretty unpredictable on pricing. I needed a set of stoppers for a 10ee turret.
    The set up fee to make (none on the shelf) was several thousand $ and the lot price something like $750 each. More common parts quite reasonable.
    Feb 2002
    Peralta, NM USA
    6,038
    62
    628
    Less simple than you might initially think. I notices once that the 1/2" notches were ground and so I set it up for checking. They were as close to .5000 as I could easily measure.
    The adjustable stops like this?:
    It might be that the spec is to make it from cast iron and they don't have a foundry easily accessible anymore. But I'm often surprised by the 'one-off' pricing from them.
  11. #11
    Jan 2020
    71
    16
    11
    I think Rich is looking for one of these...
  12. #12
    Sep 2005
    Northern California
    1,126
    189
    rke[pler
    Yeah those "stoppers" I back engineered one Al then ordered up some durabar to make the rest. Have yet to make the cutter for the dovetail, but it's on the too-doo list
  13. #13
    Sep 2005
    Northern California
    1,126
    189
    jdub63
    Rich and myself too and probably others. Any chance of the basic dimensions of the notches?
  14. #14
    Feb 2002
    Peralta, NM USA
    6,038
    62
    628
    rke[pler
    Check with AB Tools, they have decent dovetail cutters and can hook you up with one in the right angle, likely from stock.
  15. #15
    Sep 2005
    Northern California
    1,126
    189
    It's been awhile since I looked at the drawings, as I recall is was 65 degrees, thanks for the heads up.... I should re-visit that sooner rather than later.
    AB Tools is about 20 min from the house!
  16. #16
    Feb 2002
    Peralta, NM USA
    6,038
    62
    628
    I get 60 degrees looking at mine. The bottom is about 5/8" wide so you could probably get a standard HSS cutter in there, but I have to say that I do like the AB Tool cutters.
  17. #17
    Mar 2012
    Las Vegas
    842
    15
    107
    this is what i am looking for.Thanks for posting
    Quote Originally Posted by Jdub63 View Post
  18. #18
    Jul 2006
    Indiana
    573
    297
    100
    What are these worth? I have one and I have no idea...
  19. #19
    Mar 2012
    Las Vegas
    842
    15
    107
    How about $50
    Quote Originally Posted by Jim McIntyre View Post
  20. #20
    Jul 2006
    Indiana
    573
    297
    100
    I'll never use this, I'm pretty sure, but it looks nicer than $50 on my EE... Thanks anyway.
