Anyone have a front cover for a 10ee round dial?
Likes Likes:  0
Results 1 to 16 of 16
    Mar 2012
    Las Vegas
    652
    11
    64
    Default Anyone have a front cover for a 10ee round dial?
    looking for the front cover for a square dial 10ee. the one that is at your feet while you are working on the machine. it allows access too the generator junction box.
    PM me if you have one you are willing to sell and ship to las vegas
    I also need the back cover that has the vents for the exhaust from the generator.
    Rich
    Last edited by lectrician1; 03-23-2020 at 10:09 PM. Reason: mistake on the dial type
    Sep 2002
    Salinas, CA USA
    4,056
    241
    210
    I have one of those, I think it is the front cover. I’ll check and get back to you.
    Mar 2012
    Las Vegas
    652
    11
    64
    awesome rim canyon thanks!
    the machine is a square dial though. the covers should be similar though
    Sep 2002
    Salinas, CA USA
    4,056
    241
    210
    Yep, front cover. 19 ¼" wide by maybe 17-18" tall. I couldn't quite get to it to get an accurate measure on the height. Complete with knobs. $30 plus shipping. Its cast iron, from a round dial machine.
    Mar 2012
    Las Vegas
    652
    11
    64
    i'll take it.
    i will pm you my details.
    paypal ok?
    Sep 2002
    Salinas, CA USA
    4,056
    241
    210
    It turns out it is a rear cover. It has no art-deco bars, just the grills with frames around them. I'm not sure when they eliminated the art deco bars on that cover, but it might be an early square dial cover even though it is iron. Here are a couple pictures:
    Mar 2012
    Las Vegas
    652
    11
    64
    i could use that
    rear cover is missing on my machine
    thanks
    Rich
    Jul 2010
    Rochester, NY USA
    2,223
    10
    526
    I may have one for the front, I will be in the shop where the parts are this weekend, I will try to snap a couple of photos of what I have.
    Bill
    Mar 2012
    Las Vegas
    652
    11
    64
    awesome Bill! I need a front cover too. Thanks
    Virginia
    28,788
    7561
    8936
    Quote Originally Posted by lectrician1 View Post
    I have neither, here, but DO have spare:
    - the curved topmost HS cover casting
    - the smallest of a round-Dial MG-era's "hatch/doors". The one just below the MG starter switch, operator-stance side of HS base-casting.
    - a complete apron casting, gutted.
    - a complete feed gearbox casting, gutted, plus some or even all of its shafts and gears, loose.
    - front and rear 3 HP large-frame motor end-bells "only". Not the motor itself. Haven't a klew why. Could was somebody was salvaging Copper?
    ....if anyone needs any of that.
    In the other direction:
    Not a lot of hope, as often missing or damaged as they go, but I in turn need a RD MG-era HS-end rearmost cover set, both upper and lower. WiaD's fit with a skosh of mismatch on the lower - my other R-D has such. AFAIK Modular base-casting ones do not match? Or just not as well?
  11. #11
    Sep 2002
    Salinas, CA USA
    4,056
    241
    210
    Maybe the endbells were kept to make a frankenlathe type of drive. i.e. you have a mount for the 2speed gearbox and a way to support a drive shaft.
    I have the top half of the 2-piece upper headstock cover, the one used with a lever collet closer, but only the upper part, no collet closer yoke or art deco bars. $30 if it is of any use to you. This one is used on both round and square dial machines, the lower part is what changed.
  12. #12
    Virginia
    28,788
    7561
    8936
    Quote Originally Posted by rimcanyon View Post
    Makes perfect sense - we've seen several done that way. But at least the end that carried the gearbox-related mount (and bearing, still there) would have gone WITH such a conversion. This one is a leftover!
    I'll be pleased to take it, Thanks!
    You just spared a large shiney-wood New England boiled dinner steamer pot from death at the hands of a rampant sawzall!
    I have no space for an English wheel, and the radius was a decent match!
    The lower one is easier by far to fab at least a temporary dirt and "safety" cover for. At least until a better solution can be found.
    Split shiney-wood clamshell on reefer-truck lift-off hinges was in the conspiracy stage, given the CI OEM one is no longer an easy item to manhandle, my age and condition.
  13. #13
    Jul 2010
    Rochester, NY USA
    2,223
    10
    526
    My in line exciter round dial and my wiad square dial seem to take the same size cover.
    16 7/8" X 12 1/4" with the mounting pins 15 1/16" CC
    I have 2 aluminium covers without mounting handles or the art deco bars that are this size.
    These have openings for ventilation under the bars.
    Then I have an iron cover 16 1/4" X 14" and 14 7/16" CC with only 1 mounting handle.
    There is no ventilation holes under the missing bars.
    I will post photos of the appropriate cover when I am back with the camera.
    Bill
  14. #14
    Mar 2012
    Las Vegas
    652
    11
    64
    How much do you want for the cast iron cover? PM me. I think i would like to try that one.
    Rich
  15. #15
    Mar 2012
    Las Vegas
    652
    11
    64
    I got the rear cover. Thank you.
    Perfect packing. Thanks
  16. #16
    Sep 2002
    Salinas, CA USA
    4,056
    241
    210
    Glad you like it. Cast iron isn’t hard to pack, but I can’t get over the number of people who don’t know how. I learned a long time ago to wrap it with cardboard and make corners so that it is a tight fit in the box.
