I bought an EE10 (Serial # 17454, build date: 11-1942) last year and have slowly been taking it apart, cleaning out 70+ years of chips and crud, replacing crunchy bearings, etc. Once the apron was off I discovered all of the copper oil tubes in it were corroded-through, so they have all been removed and the holes where they run drilled clean. I tried soaking the metering valves in carb cleaner for 2 days, but they are plugged beyond redemption. According to this forum, I can get new ones. The question is...should I bother? Is the automatic oiling system worth the effort and cost to restore? Can I replace it with something manually operated? I haven't pulled the pump yet to see if it is functional; I've been working from the top down.
This is not a lathe I intend to restore for a museum. I want to use it. On the other hand, I am not unsympathetic to old machinery, and in fact, I bought the lathe to support my antique car and motorcycle hobby.
Any advice very, very welcome.
