gears77
- Jun 15, 2012
- Connecticut, USA
Hello All,
I am new here so forgive me if this is an old question. I have a '43 10EE that is a great machine. I have been servicing it and replaced all of the headstock sight glass gaskets, etc. I am cleaning the apron and replacing the sump gasket. In resealing the apron sight glass I noticed that it has a drain or return hole under the gasket at the six o'clock position. This is different than the other sight glasses. They have no hole behind the gasket. The hole is a clear path to the sump. Here is my question: If I install the same gaskets that I made for the other sight glasses, it will cover that drain or return hole (at 6 o'clock position). Is this hole supposed to be open via a slot in the gasket? That hole doesn't make sense to me. A gasket will block it. Any advise?
Many Thanks in advance. I truly appreciate having you all out there.. helping to keep my machine running.
Best,
Peter
Best,
Peter
