bijur metering $44 each?
Results 1 to 14 of 14
    Mar 2012
    Las Vegas
    626
    11
    61
    Default bijur metering $44 each?
    I thought about replacing the bijur metering units under my cross slide.
    i need 4 MJC -00 and 2 MJB-00
    I called bijur and they want over $40 apiece for those meters! that's about $250 just for the meters
    anyone have any other cheaper way of getting the apron lube system going?
    Some of the lines were clogged with gunk
    The pump seems to need a rebuild.
    is there a way to test the meters that i have?
    Rich
    Jul 2011
    Utah
    909
    1935
    356
    For sure replace them. I will check which sizes I have left...
    Sep 2017
    New Jersey
    135
    35
    Quote Originally Posted by lectrician1 View Post
    Rich
    Talk to Dave at Fluidline systems.
    IIRC MJ series are replaced by FJ, and fluidline has them for $17 each. Again IIRC the difference is the pump pressure required but unless lots of meter points are on the same pump as per Dave it should be ok. I have exactly this same issue with a van norman I’m working on now.
    FWIW i took an old bad meter unit, drilled it out and threaded it into an Air fitting, so I can blow out lines (gently!) with compressed air.
    This will allow you to test but not clean meter units. I’ve had some luck washing out with lacquer thinner but not always, some units are plugged.
    Jul 2011
    Utah
    909
    1935
    356
    Still have some if you need them.
    I remember Monarch wasn’t that expensive; I think 3 years ago Terrie quoted around $24 each for one, and something like $17 for the other. I may be off...
    You can have the ones you need for $15 each, if you’re interested. I’ll keep the rest for my own spares, just in case!
    May 2003
    4,540
    262
    I have successfully cleaned those meters by soaking them in a now banned non flammable solvent for a few days, then with an easily rigged up manifold, pushed solvent through the meters using about 20lbs or so air pressure.
    Oct 2011
    West-Central Illinois, USA
    1,229
    1988
    559
    Quote Originally Posted by donie View Post
    1,1,1 trichloroethane used to fix a lotta stuff like that… We should all be dead by now as much as it was used???
    After way too much patience I did manage to get all the meters cleaned on my devlieg 2b by using kerosene/spindle oil mix and a high pressure oil gun (like a grease gun). Squeeze a while, leave to do something else, rinse & repeat. Never busted a line though.
    I thought then if it ever happened again I’d make up parts needed so I could just remove the meters, take them to a diesel shop & put ‘em on the injector cleaner.
    Good luck
    Matt
    Mar 2012
    Las Vegas
    626
    11
    61
    i will take you up on that offer. So far it seems 3 of the six are working. So i might need only 3 MJC-00
    i am soaking the non working ones now in some lacquer thinner. I will know more tomorrow and i will send you a PM
    thanks
    Rich
  8. Likes TheOldCar liked this post
  9. #8
    Mar 2012
    Las Vegas
    626
    11
    61
    Default thanks fair the response
    i got a few working and a few soaking we will see what's up tomorrow
    Thanks All
  10. Likes TheOldCar liked this post
  11. #9
    Sep 2002
    Arizona
    3,611
    814
    476
    McMaster-Carr has compatible metering valves for $15 each: link (That's where I got the valves for my 10EE.)
    Cal
  12. Likes TheOldCar liked this post
  13. #10
    Jul 2011
    Utah
    909
    1935
    356
    Nice! I wish I would have figured that out when I did mine!
    I imagine crossing #s can be done on McMaster’s website?
  14. #11
    Sep 2002
    Arizona
    3,611
    814
    476
    Quote Originally Posted by TheOldCar View Post
    I'm not sure what you mean.
    It's been years, but most (if not all) of the fittings on my round-dial 10EE have UNF 5/16-24 threads both ends (which work with the compression fittings). I just ordered the same metering number that was on the existing metering units. I think this is the version that I ordered: McM part 2293k11. IIRC, the original fittings had a different shape to the inlet end, but the McM fittings work just fine. Most of the lines are an odd size, either 3/32 or 5/32, and the compression sleeves are not a common hardware store item. Someone here gave me enough sleeves to replace mine.
    Cal
  15. #12
    Jul 2011
    Utah
    909
    1935
    356
    Just was wondering if the Bijur numbers would cross. When I searched for mine 3 years ago, I struggled!
  16. #13
    Mar 2012
    Las Vegas
    626
    11
    61
    i bought everything from fluid line systems 419-535-1313
    my machine came with MJC-00 and MJB-00
    those models are discontinued
    I replaced with FJC-00 part number B3314
    and FJB-00 part number B2494
    about $15 each
  17. Likes swatkins liked this post
  18. #14
    Sep 2019
    New Jersey
    8
    Call LUBE USA (Full Disclosure) I work there. We do a lot of crossover parts from Bijur, and can probably help you out. Fluid Line is one of our customers I believe so they are also a great resource. You can test the meters by firing the pump with the line disconnected and confirm lubricant is flowing. If its a PDI meter your probably looking at less than 20 per line, and if it is SLR probably less than 10 just depending on model. If the pump is intermittent, and SLR than those metering units have filters built in and are typically recommended to be replaced yearly if the machine is heavily used, or mayber 2 years if light use.
