Bijur pump repair
Likes Likes:  0
Results 1 to 3 of 3
    Jul 2018
    North Carolina
    72
    20
    Default Bijur pump repair
    I have the Bijur carriage pump apart. Is there suppose to be an actual piston of some sort on the end of the 1/8" rod, or is the rod itself the piston?
    In the photo, there is a small metal washer and some kind of rubber washer. I'm embarrassed to say that I don't remember where they came from when I took the pump apart. I think they were under the input check-valve. Anyone else disassembled one of these?
    BTW, I've cleaned both check relief valves and they seemed to work well against compressed air.
    Jun 2007
    Nevada
    429
    42
    I can’t remember specifically since it has been almost 2 years since I had mine apart, but as I remember the parts all fit together pretty obviously. The o-ring probably only has one place it can go. The pin is the piston. I was amazed at the pressure the little pump put out after 60 years. I replaced the disgusting felt with soft felt sheet I had from McMaster, maybe F10? You will likely have to replace the Bijur meterers in the carriage and saddle as well. I attached mine to the electric one shot Oiler on my mill and I think all but one were completely blocked.
    Jul 2010
    Rochester, NY USA
    2,153
    9
    501
    This thread covers the metering units and some pump issues.
    10EE Oil Pump Operation and Flow????
    The rubber washer may fit under the suction check valve. Compressed air is a bit extreme to test this check valve.
    I normally make sure it will open freely with mouth suction, and when seated checking for leakage by suction on the other side.
