Boeing EE
Page 1 of 18 12311 ... LastLast
Results 1 to 20 of 352
Thread: Boeing EE
    Jul 2013
    Sequim WA.
    465
    111
    109
    Default Boeing EE
    I just got this Boeing EE I hope to rebuild It was listed on CL paid $3000 + $800 to move it to Sequim, WA.
    It's a 10 by 20 S/N 48890 5/1967 and rebuilt by Boeing in 73
    Some parts are missing the follow roller on the drive belts and the speed pots, the ways need grinding Lindmark in Seattle will do it for $1000.
    I'm new to this forum so I hope you all will bear with me as I get up to speed, Will keep you up to date with photos as I do the rebuild.
    I got a 3 HP motor from the guy too It needs a home. Look clean I think it just had a clean dip and bake the comm is not under cut. If you need a motor make offer.ee-motor-161.jpgee-lathe.jpg
    Jun 2010
    santa cruz, CA
    821
    1994
    716
    Congratulations on getting it. You have a lot of reading ahead of you. I don't think that I am wrong in saying that just about everything you can possibly ask has already been answered (in many cases multiple times). Go to the search arena and type in Monarch EE. That is a beginning. By the time you emerge, you will know more about these lathes than you need.
    Lee (the saw guy)
  3. Likes vmkelley liked this post
    Jul 2013
    Sequim WA.
    465
    111
    109
    Thanks I will be using all the help I can get
    I worked for Boeing for 2 years in 72 and 73 at A3510 in plant 2 on 3rd shift a shop called the gear line. the shop had 3 EE, the only work I did on the EE was to put a chamfer on 28,000 flap drive couplings.
    One of the hard parts is do I keep it as is with the tube drive or upgrade it the Beel stuff is $1500 I keep the old 5 HP dc motor and it runs off my single phase shop power or get a black max 5 hp and a 7 1/2 hp Hitachi VFD and a 3 phase converter. that's more than $1500. Just keeping the old tube drive stuff is going to cost $600 for a phase converter and them the coolant pump
    And will the Beel stuff even work?
    Feb 2002
    Peralta, NM USA
    5,643
    48
    462
    Quote Originally Posted by Sequim Tool View Post
    You can run everything except the coolant pump on single phase. The coolant pump can be changed to use either a small VFD or something like a little static phase converter. I'd disconnect the pump and just run it on single phase for a while.
    Dec 2002
    Monterey Bay, California
    10,260
    28
    214
    IF the coolant pump is the usual Brown & Sharp Model 200, it is a C-face pump which may be mounted on any 56C frame motor.
    In such a case, simply remove the 1/3 HP three-phase 56C motor and replace it with a single-phase 56C motor.
    Of course, the pump's compartment has precious little headroom, so the capacitor "hump" will have to be relocated.
    But, that is really a pretty simple job.
    Brown & Sharp pumps are now made by BSM Pump, as a successor to B&S.
    Jul 2013
    Sequim WA.
    465
    111
    109
    It's a 1/4 HP Gusher and yes I can just get a new single phase motor and stub the shaft to fit the impeller. Gusher made the same pump in single phase too, one was just on e-bay he wanted $350. good luck to him with that price.
    It's the speed pots I need to find, all I have is the shaft with the small bevel gear on it.
  8. Likes Shaperdave liked this post
  9. #7
    Feb 2003
    Louisville, KY, USA
    3,245
    5
    152
    I'll be the Heretic here, which is nothing unusual. Drop a Little Giant pump in the coolant sump, do a little electrical work to get 120 V to the pump, and you should have under 200.00 in the coolant system. It's as easy as that.
    Harry
  10. #8
    Dec 2002
    10,260
    28
    214
    "It's the speed pots I need to find, all I have is the shaft with the small bevel gear on it."
    The dual Clarostat 5W wire-wound speed pot is a special.
    I have seen those on eBay for about $50.
    But, they are rare.
  11. #9
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,525
    439
    2055
    Why would it have been rebuilt five years after being made?
    3 shifts a day 367 days a year work?
  12. #10
    Virginia
    26,861
    7561
    8408
    Quote Originally Posted by peterh5322 View Post
    But, they are rare.
    Rare, but not AS rare as the much heftier ones the MG 10EE's used. They can be fabricated by altering stock parts. though it is a tedious task.
    While seeking the proper parts, one can get up and running to see what else needs attention with two more-common ordinary variable-resistors that are NOT ganged:
    - Set the field to full power and leave that control alone.
    - operate from base-RPM and downward setting only the armature knob.
    - once at full-armature voltage, CEASE touching the armature voltage knob and dial the field power downward to increase RPM.
    CAVEAT: You will need some sort of mechanical stop to prevent field voltage going too low and leading to an unloaded motor overspeeding.
    Dropping armature voltage whilst the field is not at full power, is not as risky. It just drops the available torque reserve at any given RPM vs torque at full power to the field.
    Bill
  13. Likes nofxz liked this post
  14. #11
    Jul 2013
    Sequim WA.
    465
    111
    109
    some guy is parting out his EE on E-Bay I hope he will have the parts I need. This photo show the missing follower or some thing
  15. #12
    Feb 2007
    upton ma
    1,668
    48
    173
    I seem to remember someone buying the dual clarostat ot from monarch for something in the area of $100. It did not strike me as a bad price.
    I may have a pulley or two in the parts I have. I'm sure I dont have the arm for the pulley on the right side that you show (missing) as I eventually found one on ebay as my machine was missing that part as well. I think there may be a sketch if you search, I can do one for you if needed.
    Paul
  16. #13
    Jul 2013
    Sequim WA.
    465
    111
    109
    one listed on E-Bay today he want's $120 it has spur gears on it. the gear on shaft on mine is a bevel gear?
    This photo is the of my machine
    And does anyone want my 3 HP motor or is it just scrap.
  17. #14
    Feb 2007
    upton ma
    1,668
    48
    173
    The bevel gear you show is the same think that is in my modular drive. Unfortunately it looks like you are missing the pot, the mating gear, the casting it attaches to and the cover. I dont think I have any spares of those parts but I will take a look in the next few days. Monarch may have "take off's" from a machine they convert, I've heard they price some of the take off parts reasonable, Can also supply rough sketches if needed.
    On the motor - you are likely to find a home for it eventually maybe $100 if you have a place to store it - and someone local needs it (they are heavy as you no doubt know). The back gear is more in demand, Last one that I noticed on ebay went for about $300, there is one on there now with a current bid of about $10 that closes today so we'll see if there are many people looking. In all the parts I picked up I now have 2 complete motor back gear assemblies, another nice condition back gear and a 4th back gear that appears to be all there but will need some work from someone. I've got space so I can be patient and plan to offer them for what I think should be reasonable $
    Paul
  18. #15
    Jul 2013
    Sequim WA.
    465
    111
    109
    Thanks Paul
    well I got the pot's listed on E-bay he was asking $120 gave him $60. He is parting out a 72 EE.
  19. #16
    Dec 2012
    northwestdioxide northwest
    36
    12
    Sequim Tool
    You have a PM
  20. #17
    Jul 2013
    Sequim WA.
    465
    111
    109
    The good Dr. can use the Motor he saved it from junk dealer at a good price too, free.
  21. #18
    Jul 2013
    Sequim WA.
    465
    111
    109
    Default speed pots
    Got the speed pots but not looking to good $60 + $41 shipping
  22. #19
    Feb 2002
    Peralta, NM USA
    5,643
    48
    462
    Don't lose that little brass dingus on the floor nest to the screw - it's what's used to connnect the pots. You've got both sides and they're usually easy enough to put together.
  23. #20
    Jul 2013
    Sequim WA.
    465
    111
    109
    No luck pots are open $101 down the tube on junk parts off E-Bay But it's not Norm's fault he never tested them. It's my fault for not having him test them.
