Early Square Dial Cross Feed Dial Question
Results 1 to 10 of 10
    Sep 2002
    Salinas, CA USA
    4,875
    550
    456
    Default Early Square Dial Cross Feed Dial Question
    My 1949 Mfg. lathe came with the dial assembly below. Looks a lot like a round dial dial assembly, right?
    Here is a photo that shows it in comparison with the more common square dial dial assembly:
    I would like to add a chasing stop to the early dial assembly. Monarch tells me they cannot find a parts drawing that shows that combination; i.e. all the dial assemblies they are aware of with chasing stops are of the later style. So are they correct? i.e. do any of you have an early Square Dial with the older style dial assembly that has a chasing stop?
    Mar 2002
    dallas,tx
    2,740
    794
    594
    Is there enough room in there for all those stops, like on the later dial?
    Sep 2002
    Salinas, CA USA
    4,875
    550
    456
    Quote Originally Posted by daryl bane View Post
    Definitely. The stops are the same for round dial and square dial, it all works the same. As I said above, these look a lot like round dial parts. Maybe Monarch continued to use them on square dial machines.
    I have two of these dial assemblies, both are missing the stops, so maybe they were only used on mfg. lathes. I hope Donnie responds, there aren't too many mfg. lathes on the forum.
    Dave
    Jul 2006
    Indiana
    573
    300
    100
    Can't help other than to say the 'chasing stop' is one of those 'smile every time you get to use it' features of the EE. It works. It's intuitive. It's a brilliant design.
    Good luck!
  5. Likes old_dave liked this post
    Oct 2015
    AUSTRALIA
    147
    46
    That must be a round dial assembly as it looks exactly like whats on a CVA which is half cloned straight from an early 10ee.
    Sent from my SM-G973F using Tapatalk
    Jun 2004
    Idaho
    269
    175
    54
    Red face
    My 1946 square dial has the chasing stop. It's the revolution counting dial with the chasing stop, I figured they came standard with the ELSR. Bill
    Oop's, looks like you are talking about MFG lathes, never mind....
    Sep 2002
    Salinas, CA USA
    4,875
    550
    456
    Quote Originally Posted by BillDe View Post
    I heard from another member of the forum that he has a rev-counting dial (actually called an accumulating dial by Monarch) that came on a mfg. lathe. It was missing the chasing stop. So that is an unusual combination for sure.
  9. #8
    Jun 2004
    Idaho
    269
    175
    54
    When you say the stops are missing, are the dials not machined? Or are they ready to accept the parts necessary to have the stop?
  10. #9
    Sep 2002
    Salinas, CA USA
    4,875
    550
    456
    The base casting, the part with a two hole flange that bolts to the cross slide, is machined with a recess for the three stops and it is threaded for the screw at setscrew. The dial portion is machined for the center bushing that the stops fit on, but it is not machined for the dowels that contact the stops. So to convert this early dial I would just need the stop screw and to drill the dial for a pair of dowels, plus the stops.
  11. #10
    Jun 2004
    Idaho
    269
    175
    54
    OK. Well that gov't auction lathe has one sitting in the chip pan LOL...
