I've started disassembling my 1942 EE10 carriage and ran into a problem. There is a shaft with a cam that operates the oil pump, and bearings at either end hold the shaft in the carriage.
Taping the shaft to one side slides the bearing out of the carriage housing, but the high point on the cam then bumps up against the carriage on the inside, preventing me from removing the shaft. The hole is not big enough to pull the cam through without both bearings being out so the shaft can be moved to one side. It looks to me that the only way that shaft could have gone in there was slide in the shaft and cam, then install the bearings afterwards. However, the bearing appear to be a press-fit on the shaft, OR they are stuck tight to the shaft.
In this photo you can see where I've taped a bearing out of the housing, but cannot go any further because the cam on the inside won't fit through the hole.
Suggestions? Should I put a bearing puller on the shaft? Do I have my head up my kiester as usual?
