As a result of my belt length woes I am puzzled as to feed rates. Terrie tells me that there is only one Monarch flat belt at 37 inches long, way too short for my machine.
There are two different spindle drive setups, one with the flat belt running on the spindle, the second the flat belt running on the convex aluminum sleeve.
There are (at least) two different gearbox driven pulley part numbers: EE1009 and EE19889.
To have the same feed rates, the type running on the spindle would have to use a smaller driven pulley than the aluminum sleeve type, which would require different belt lengths. However, to use the same length belt, the spindle driving type would have to use a bigger driven pulley and conversely the aluminum sleeve type would have to use a smaller driven pulley, which would then produce different feed rates.
Making it more puzzling, I have three data points: mine, a friend's and Labeeman, whose lathes use belts 38-38.5 inches long, which goes counter to what Terrie is telling me.
Mine and my friend's driven pulley is 7&3/8 inches OD.
