peterh5322
- Dec 15, 2002
- Monterey Bay, California
It is my objective in this thread to document some of the information, including "gotchas", discovered during the design and implementation of a retrofit drive for my 1956 Monarch 10EE (3 HP, WiaD).
Most of the information I post will be my own. However, some may be paraphrased from other sources (with attribution, of course, where known). Comments and constructive criticism is invited.
240 volt single-phase operation is the goal, with "four quadrant" operation and full support of the 10EE's Reliance 3 HP compound wound motor. After support for compound wound motors is confirmed, support for shunt wound motors (the Ward-Leonard 10EEs) should follow directly.
I'm starting out with a few "baby steps", so please bear with me.
Support for 230 volt dc (armature and series field), 115 volt dc (shunt field) motors appears to be impossible with "open frame" and "packaged" drives operating on 240 volt single-phase power. Several commercial "packaged" drives have been identified which provide this support, but these are three-phase only.
Many drives are actually intended for the more modern permanent magnet ("permag") motors, not the older, conventional motors which are found in all 10EEs.
Some very interesting considerations were recently identified in DANAHER MOTION's publication on their M4000 Series of 5-1000 HP drives.
In the section titled, "Special Motor Considerations", I found this tidbit.
"The Mentor II Drive nameplate is for 240 VDC Armature and 150 VDC field for a 230 VAC 3 phase input. ... The MDA3 Field Current Regulator is set at the factory based upon a typical motor's nameplate data. This means that the drive's settings will get you in the ballpark but they may have to be adjusted to obtain the motor's nameplate speed and full torque capabilities with your specific motor. ... Old MG set motors ... are notorious for uncommon motor nameplates. Note! Be careful when using the Mentor II Drive with a motor what was previously used on a MG set. The motor inductance may be too low and drive tripping and erratic behavior may result. In this case an output choke may have to be installed in the armature circuit."
I am presently proceeding with my design based upon two commercial "open frame" drives which are designed for 240 volt operation. The identity of these drives will be disclosed later.
As usual, these drives only support 180 volts dc (armature; maximum, variable) and 90 volts dc (field; maximum, fixed), are "single quadrant", which do not specifically support compound wound motors, and which do not support "field crossover"/"field weakening" at all.
My initial investigation will be:
1) converting these drives for 288 volt operation, this 288 volts being obtained through the use of an autotransformer (or autotransformers), connected in "boost" mode,
2) converting the first of these drives to develop the required 230 volts dc, 14 amps (maximum; variable) for the armature and series field, and
3) converting the second of these drives from full-wave to half-wave operation in order to develop the required 115 volts dc, 2 amps (maximum; variable, for "field crossover"/"field weakening") for the shunt field.
Peter.
[This message has been edited by peterh5322 (edited 04-28-2003).]
Peter.
