lathehand
Cast Iron
- Jan 31, 2005
- San Francisco Bay Area
It works! The DC drive sold through this BB is running my Reliance 3hp DC motor and I had a message that Julian has had his GE 5hp motor running. This was a "learning experience" and part of that experience was a $185 phone call to GE Customer Service to learn something that was in a newer version of the operating manual but not in my copy: this drive requires a tachometer for speed feedback if it is to operate in field weakening mode. So I had to add a tach generator to the "off" end of the motor shaft.
Some general comments about this conversion: this drive is very sophisticated and the manual does not supply all the information required to program for different uses. We were very fortunate that the drive was originally configured for a for/rev, field weakening, regenerative braking spindle drive with analog tach feedback. But the speed control was a 0-10v signal from the machine controller. There was no information anywhere about converting the drive to manual speed control with an external potentiometer, nor was it very clear how to install the external for/rev switches. Julian obtained this information.
Some of the changes required to program this controller for a different motor were in the start-up guide and were simply changes in jumper locations in various circuit cards. Other changes required the use of either a hand-held controller or special software installed on a computer. Some of the parameter changes were in the manual, others had to obtained from GE. I asked the GE engineer if he could simply input my motor parameters into his software and print out my drive parameter list. He was puzzled by the request and said that he did not have that capability and didn't even know who did. The drive was programmed for its intended purpose at the factory and was apparently not expected to be significantly changed in the field. GE does not publish all the parameters, their values, and the engineering decisions required to program the drive. The lesson: drives of this this type may not be field re-programmable, and will definitely require access to either a hand-held programmer or computer software. You cannot just look at the wiring diagram, add a 5K pot and some switches to a terminal board.
Do I like the drive: you betchum! It is connected temporarily and the motor is sitting on the welding bench, but it has been in the lathe and running the spindle. Low speed torque is incredible, acceleration and deceleration are impressive. As part of this project I will compare it with my working WIaD and report to the BB.
One other detail: the drive operates quite well on my 3hp 3ph rotary converter, but it has not yet been loaded by making a cut. The lathe is still apart for cleaning, maintenance, and repair.
