Getting a Monarch Series 61 Back in Service - Page 9
Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 221
  1. #161
    Sep 2016
    Missouri
    1,240
    1024
    418
    That's an interesting tap. I see it takes a conventional thread cut then finishes out to acme. Easier on the tap.
  2. #162
    Sep 2002
    Arizona
    4,143
    1029
    713
    Quote Originally Posted by texasgunsmith View Post
    I'm also planning on specialized nuts to fit through hole in compound, for compound rest retaining studs. The squares on current bolts are not perfect fits and dig into the cast iron. I plan to make large fit nuts to slip in there. But that's another side adventure. . .
    Attachment 300053
    I don't know if it's the same on your Series 61, but 'T' part of the bolts on my 10EE aren't square, but are a section of ring. That is, radiused on both sides. I don't have a closeup of one, but you can see what it's like in this photo, above the big hole in the top slide:
    Cal
  3. Likes texasgunsmith liked this post
  4. #163
    Feb 2016
    2,358
    1644
    1015
    Damn Cal ! You're stealing my future story.
    That's exactly what I want to make ! Not an exact plan, but in my head I was going to use a slotted drive plate on a lathe. Set up two pieces out on the drive plate, at about the diameter of the circle on compound. Length of the two pieces, to just clear into bottom entry hole. The cut would leave them radius-ed, hopefully a nice fit.
    Or just cut a full circle on lathe same diameter, then cut the two pieces out. But need more material this way.
    I don't have an idea as tee bolts, figured I make them nuts, and use studs same length as current bolts. Locktite studs in. I guess brazing them as mllud22 suggested is not a terrible option. I have time to think on it anyway.
  5. #164
    Sep 2016
    Missouri
    1,240
    1024
    418
    The only reason that I can think of that they use the bolts is so it would be easy to set the compound down over the bolts and put nuts on. Lock-tite would be better. I braze everything, old school thinking.
    Your radiused nuts like Cal showed are the fix.
    My comment about the bondo being a built in buffer was dry humor but did work as a dull thump warning when I bumped the jaws. A little filler beats looking at gouges.
  6. Likes texasgunsmith liked this post
  7. #165
    Virginia
    21,988
    7561
    12673
    Quote Originally Posted by mllud22 View Post
    Nah. Just cut you a few slices out of a not fully-perished disk brake pad, and yer good to go with drop-in replacements!
    As to the CR hold-downs?
    Yes, ideally you'd want longer curved segments, even a full-circle ring. To GET a full ring, the center section has to be a separate piece, itself dowel-pinned with retention fasteners.
    Been done by others, elsewhere.
    Needs more DEPTH to it than we would want to give-up, here. Otherwise the ring simply distorts, remains distorted. And now you have a "binding" problem you did not previously have.
    Comes a point where improved rigidity is needed, a(ny) compound rest is simply removed and asided.
    A monolitic toolholder takes its place. USUALLY with an attach system more direct. Independent dowels and bolts, outside the compound's ring. It just isn't that hard.
    Galis, doing mining and rail rebuild work, most of it involving corn-cob DC stick-weld cutback, the compound spent a week or three at a go laying six feet down the chip tray. McCrosky 4-Way lifted into place with the overhead crane was all we needed, straight-in single-point threading included.
    The compound went back on for short tapers. Only.
    That 'scales" down as well as up, BTW.
    A compound is an accessory, not a necessity, watchmaker size to a Craven Brother's.
    Myfords, Boxfords, other tiny "British Model Engineering" favourites have relied on a "Gibralter" replacement for the compound to take better advantage of their very austere "stiffness rations" for ages.
  8. #166
    Feb 2016
    2,358
    1644
    1015
    Getting close to starting back on this. Picked up some oil I plan to use for this, and I think will become my "default" oil of choice for most related items. Going with DTE Heavy, which is equivilent to SAE 30w.
    I've been using DTE Heavy/Medium for other things. Living in the South with warmer climate I should do fine with the DTE Heavy. Rubbing it between my fingers feels a little more slick than Heavy/medium.
    I wanted 8 gallons to start. Checking MSC Direct, they want $35 per gallon plus shipping and tax. I went to a local distributor here in Houston, J.A.M. Distributors. I bought two cases, of four 1 gallon containers. The grand total including tax was $230, plus an hour and half of my time to travel and pick it up. FYI to those in the area, you need to place the order prior to picking it up, don't just go there. Anyway I probably saved $100 on 8 gallons, going there.
    J.A.M. doesn't offer a decription, just the name DTE Heavy, knowing there's a great many "like" oils for hydraulics and such I wanted to verify.
    The cases I received:
    The cases and the gallon jugs had the same label:
    Using the product code I verified through a different distributor. All the oils can have multiple product codes for the same oil, the different is in the quantity. According to my product code it is DTE Heavy Bulk. It would have a different product codes for 5 gallon pails or 55 gallon drums. J.A.M. must package the one gallon containers themselves. The jugs do have an aluminum seal under the cap though.
    Products codes by number:
    http://theoilnet.com/Atlantic-States...ustrial-19.pdf
    Product codes by oil name:
    Mobil All Industrial Products
  9. #167
    Feb 2002
    New Mexico
    6,082
    63
    649
    Oils are usually a lot cheaper by the pail. I think the last pail of DTE 24 I bought came off Amazon for about $124 delivered, I'm not sure I can beat that with local folks.
  10. #168
    Sep 2016
    Missouri
    1,240
    1024
    418
    Going back too your crossfeed nut adjustment. Here is a photo i took of the screen during a video. It shows what you need.20201026_093546-8873-.jpg
    Its at 2.33 minute's on an American pacemaker video.
    American Pacemaker lathe reassembly part Zero - YouTube
    I will be bringing that old Pacemaker home. Not the one in the video.
    Notice the undercut on the bolt on the left half. Allows side movement.
    You have lube.
  11. Likes texasgunsmith, Cal Haines, TheOldCar liked this post
  12. #169
    Feb 2010
    Illinois, USA
    688
    29
    209
    Just for future reference, don't buy gallons. Mobil sells DTE heavy medium in 5 gallon pails (or 55 gallon drums if you're so inclined) and a local distributor that I have no account with sells it for $112 over the counter. I used it in my Monarch 61, and my K&T 2K.
  13. Likes TheOldCar liked this post
  14. #170
    Feb 2016
    2,358
    1644
    1015
    Yea, with rke[pler mentioning the same. In retrospect, I should have this time. With initial fills of headstock, apron, and qcgb coming. Wished i had priced it out to know.
    In my head I was thinking of running under normal circumstances, where I'd rather handle a gallon jug for minor fills.
  15. #171
    Feb 2002
    New Mexico
    6,082
    63
    649
    Keep the gallon jugs and fill them from the pail. My pails are out in the fabrication end of the shop and the gallons are in the enclosed and heated end. Handy that way.
  16. Likes texasgunsmith, TheOldCar liked this post
  17. #172
    Feb 2016
    2,358
    1644
    1015
    A little off topic, but I bought it to go with this lathe, so I figured I share.
    A couple of months back daryl bane posted a thread on a Monarch tool cabinet here:
    Monarch Tool Cabinet resto
    In it I suggested if he found another to let me know, half joking. Well another member contacted me, rke[pler, said he had a spare, and if we happen to cross close to where either lived, maybe we could work something out. As it turned it out, the Friday it happened.
    While maybe known more as a 10ee toolcabinet, I also found it in a 1957 catalog for Series 61's, so I'm rolling with it, haha. Thanks to rke[pler for making it happen. The catalog for 1957, page 42:
    Monarch Machine Tool Co. - Publication Reprints - Model 61 Engine and Toolmakers Lathes - Catalog | VintageMachinery.org
    The pdf from that link:
    http://vintagemachinery.org/pubs/2103/19568.pdf
    And the pic from page 42:
    Getting it unloaded today:
  18. Likes triumph406 liked this post
  19. #173
    Feb 2016
    2,358
    1644
    1015
    More pics of the cabinet:
    Nice spring latches and handles, though the handle on door may not be original. Odd because it matches the style of other two handles. But in probably a 60 plus year life, who knows what adventures its seen, . I like them and will probably leave them as is.
    Spring lathe on drawer original I believe:
    Once I have a whole lot more pieces hung on the lathe, I will get to restoring this. Same paint scheme as lathe. And start a different thread on the tool cabinet.
  20. #174
    Feb 2002
    New Mexico
    6,082
    63
    649
    Glad we could get together and that you made it home intact. I made it back with the bandsaw - 2200+ mile round trip. Living in a tool desert makes life interesting.
  21. Likes texasgunsmith liked this post
  22. #175
    Feb 2016
    2,358
    1644
    1015
    Pretty much finished up another project lathe. Spent the past week or so cleaning up the remnants, and trying to get my shop in order. It seemed like a parts explosion . Catching up on a little maintenance on some other machines as well.
    As part of the clean up, one thing I had been procrastinating and was gnawing on me. Where to put the Monarch tool cabinet. I really wanted it against wall on headstock side of the Series 61. Ultimate goal is to put the tool cabinet on wheels when I restore it. But I hadn't really allowed enough room when I set bases and bed on the machine.
    Truly loathed the idea of moving the machine, but I know its only going to get heavier as I add pieces. Plus I would forever be un-satisfied if I placed that tool box somewhere else . So I set up to drag the machine about 8 inches to the right. Worked out better than expected. I just took up some weight, and shoved it over with a pry bar, an inch at a time.
    Got the 8 machine feet under the leveling adjusters, and went about getting an initial level again. This time I just went right to the Starrett No 199 and got it to within .0005". I'll do a recheck in a few weeks. Head stock and tail stock ends:
  23. #176
    Feb 2016
    2,358
    1644
    1015
    Besides leveling front to rear, I wanted to set headstock side a little high. I went for the .015"-.020" range.
    I'm not filling it yet, not till I restore it a bit, but got the tool cabinet in where I wanted it.
  24. #177
    May 2020
    Indiana
    304
    81
    137
    Why the slightly raised headstock? Not that I see anything wrong, just curious.
  25. #178
    Feb 2016
    2,358
    1644
    1015
    Quote Originally Posted by rabler View Post
    If I decide to use coolant, it'll help get the the fluid running toward chip pan or tail stock end, verse toward head stock or the gear end.
    Even if just oils, I'd rather have it creep toward tail stock end.
  26. #179
    May 2020
    Indiana
    304
    81
    137
    Good thinking!
  27. #180
    Feb 2016
    2,358
    1644
    1015
    Good thinking!
    Something I learned from Practical Machinist actually ! Read it from more serious machine re-builders like Forrest Addy, Richard King, etc. Since then I've been setting my lathe headstocks a little higher than tail stock side.
