I am refurbishing the $150 Monarch... I've searched the posts on slide removal and I am not finding the help I need. My Bottom Slide is being stubborn. I've removed the Crossfeed Dial Assembly from the front and disconnected the Crossfeed Screw Bearing (between the Taper Attachment and the Carriage) at the back end. The slide gib has also been removed. Despite gobs of clearance in the gibs, the Bottom Slide and Draw Bar will not lift off.
From the attached photo, what the Monarch parts manual calls the Clamp Screws are removed. The slotted "Crossfeed Nut Lock Screw" won't budge with a manual impact driver, at least in the normal RH direction.. I quit before I tore up the slot. This isn't a LH thread is it?
From what I can see it is the only thing holding the Crossfeed Nut in place. If this won't come out, it looks like the Taper Attachment would need to be partially disassembled to slide the Feedscrew, Draw Bar, and Bottom Slide out the back.
Anyone know how to get this thing apart?
