Help me with what this is?
Results 1 to 14 of 14
    Dec 2017
    ALAND ISLANDS
    51
    8
    Default Help me with what this is?
    Not sure what this is. Can some one help?
    Nov 2007
    marysville ohio
    9,423
    2705
    6256
    Quote Originally Posted by Will McRay View Post
    That is a 4 11/16 square box and cover.
    Jul 2010
    Rochester, NY USA
    2,187
    10
    516
    It looks like a transformer on the back of a Monarch EE.
    That is a 4 11/16" square junction box on the top of the transformer.
    Mar 2011
    Geneva Illinois USA
    6,215
    2666
    2411
    Take the cover off and look inside. It probably is just a junction box for the leads going to the transformer.
    Tom
    Dec 2017
    ALAND ISLANDS
    51
    8
    What I don’t get is, what is it used for? Nothing is hooked up to it.
    Feb 2013
    North Carolina
    414
    511
    156
    Turn that switch OFF before you do anything.
  7. Likes fusker liked this post
    Oct 2004
    Montana
    1,076
    61
    51
    It is probably just used as a connection box, to keep the electrical wire safe and mouse proof.
    Open it up and have a look.
    Hal
  9. #8
    Oct 2018
    Ohio
    203
    182
    36
    If its not used (no wires in it) the previous machinist probably hid his lunch money in there.
  10. Likes fusker liked this post
  11. #9
    Mar 2002
    dallas,tx
    2,503
    551
    459
    Just a guess( mine is inside) it is a 120V step down control transformer that was used to power the main contactor board, plugs for a worklight, blower fan, and a host of protection solenoids, backgear, and spindle lock. Now if your original drive has been scrapped, it is superfluous. And it might be just an empty box.....
  12. #10
    Dec 2017
    ALAND ISLANDS
    51
    8
    Quote Originally Posted by daryl bane View Post
    Best answer yet. Thank you. The lathe is all original so I guess the transformer still has a purpose.
    Will
  13. #11
    Mar 2018
    Virginia
    50
    20
    18
    Who says if it has stuff going to it if you haven’t opened it? Those boxes usually have rear knockouts.
    There could be wires coming in from the sides you can’t see.
  14. #12
    Mar 2011
    Geneva Illinois USA
    6,215
    2666
    2411
    Sounds like Geraldo Rivera's opening of Al Capone's vault.
    Tom
  15. #13
    Virginia
    27,630
    7561
    8604
    Have the same rig on the back of a 12" Sheldon shaper. It allowed for less hassle in the mag starter. Given uni-directional use of the motor, no juice-pump, there isn't anything else but a safe worklight, common lamp ratings, off 3-P at any of several voltages for the "system".
    10EE, depends on age and budget.
    Example: As received,, the OEM wiring for the worklight on my 1942 AKA "wartime" MG-era 10EE was fed with just ONE wire off a leg of the 3-P incoming.
    The other side was grounded directly to ... the bed casting.
    Electrons being shamelessly agnostic - even outright opportunistic hoors - as they be, any standard Edison-base incandescent lamp - of the appropriate Voltage - worked fine.
    Wire, box, transformer materials, labour, delivery time were freed-up for something more desperately needed to win a war.
    Gentler times, less strained budgets, yah goes back to doing it proper-like. To "code", even.
  16. Likes Will McRay liked this post
  17. #14
    Dec 2017
    ALAND ISLANDS
    51
    8
    I got the original order on the lathe and I did not see a light but I seem to have had a coolant pump so I assume that pump was fed by that transformer.
    Thank you for the additional education!
    Will
