HELP!: Monarch 10EE Jerky/Jumpy/Stuttering Spindle from 0 - 1,400 RPM
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Jun 2009
    Kentucky USA
    127
    68
    17
    Default HELP!: Monarch 10EE Jerky/Jumpy/Stuttering Spindle from 0 - 1,400 RPM
    Need Suggestions on what to Check on my 1969 10EE:
    The Spindle/Motor Drive Stutters/Jerks/Pulses from 0 - 1,400 RPM after that it runs smooth.
    I have replaced all the Module Diodes with new Modern ones.
    I have tried locking out the QSD contact, no change.
    My Tube Filament Voltage is perfect at 2.5volts.
    If I set the RPM at higher RPM’s and stop/start the spindle it smoothly accelerates to the set RPM, no issue.
    Machine is a Factory Badged 460 volt. It is powered by 220Volts single phase connected to a Step Up Transformer which is providing 468volts.
    Any Suggestions on what to check would be appreciated.
    Kind Regards, Ken
    Feb 2002
    Peralta, NM USA
    5,790
    52
    522
    Is it only jerking and stuttering when you're changing the speed? If so it's possible that there are problems with the armature control potentiometer. You might be able to confirm it by seeing if very fine movements near one of the stutter points can't find a dead spot.
    Jun 2009
    Kentucky USA
    127
    68
    17
    Quote Originally Posted by rke[pler View Post
    It does this at any setting from 0 to 1,400. It does it whether the RPM dial is stationary or slowly advancing.
    Could it be the FA Relay?
    Feb 2002
    Peralta, NM USA
    5,790
    52
    522
    Quote Originally Posted by Mac007 View Post
    I don't think it could be the relay. The thing is - from 0-1400 rpm the armature voltage is changing and the field is supposed to be constant, after that the armature is constant and the field is changing. Having the field or the armature changing outside your control could reproduce the effect you're seeing.
    Could you video the lathe while it's doing this and put the video up on youtube? It might help narrow down the possibilities.
    Jun 2009
    Kentucky USA
    127
    68
    17
    I have posted the video:
    YouTube
    And here is another video at a higher RPM, SMOOTH.
    YouTube
    Mar 2016
    Louisiana
    437
    220
    79
    Check your field voltage it should be full voltage at the lower rpm's and that relay should not be kicking in. That relay should only kick in when the motor draws a high current on the armature to apply full field to the motor. Wirh that relay kicking in that tells me that YOU DO not have full field.
  7. Likes Colt45 liked this post
    Feb 2002
    Peralta, NM USA
    5,790
    52
    522
    Quote Originally Posted by labeeman View Post
    Yup, it's the Quick Slowdown Relay pulling in.
    I'd suspect the C3J, the smaller of the tubes in the tube panel.
  9. Likes labeeman liked this post
  10. #8
    Jun 2009
    Kentucky USA
    127
    68
    17
    To check this voltage do I probe F2 and 18? Multimeter set on DC.
    Documentation say 120 VDC.
    If its not 120 VDC, what do I check next ??
    Kind Regards, Ken
  11. #9
    Mar 2016
    Louisiana
    437
    220
    79
    See above your post
  12. #10
    Mar 2017
    137
    29
    60
    buy and replace the C3J vacuum tube is what he said
    https://www.ebay.com/sch/i.html?_fro..._odkw=c3j+tube
  13. #11
    Jun 2009
    Kentucky USA
    127
    68
    17
    [QUOTE=John S01;3469715]buy and replace the C3J vacuum tube is what he said
    https://www.ebay.com/sch/i.html?_fro..._odkw=c3j+tube[/QUOTE
    I have already purchased and replaced that tube. But no change.
    Not sure how I can tell if the C3J I bought is good, or the one I replaced was good.
  14. #12
    May 2003
    4,752
    432
    Have you correctly adjusted the two trim pots in the module, one is for top speed the other is speed compensation?
  15. #13
    Mar 2016
    Louisiana
    437
    220
    79
    [QUOTE=Mac007;3469897]
    Quote Originally Posted by John S01 View Post
    What is your field voltage? If not up to 120VDC you have a problem with that circuit and the first thing you do is change the tube which you have done but if your 120VDC is not right that circuit is the problem if your 120VDC is there then you can leave that circuit and look for something else. Also check your field voltage on the motor it self that will tell you if the wiring is good.
  16. #14
    Jun 2009
    Kentucky USA
    127
    68
    17
    Quote Originally Posted by donie View Post
    Yes, I have gone thru that procedure and it corrected an OVER-Reving issue I had. When you set the RPM at say 2,000 and started the Spindle it would over shoot to apx. 3,200 and then settle back at the 2,000 setting.
    Now it smoothly accelerates up to the RPM setting without over shooting.
  17. #15
    Jun 2009
    Kentucky USA
    127
    68
    17
    [QUOTE=labeeman;3470018]
    Any directions on how / where to check this Field Voltage? Thanks
  18. #16
    Mar 2016
    Louisiana
    437
    220
    79
    [QUOTE=Mac007;3470060]
    In the pecker head of the motor there should be wires labeled F1 F2
  19. #17
    Jun 2009
    Kentucky USA
    127
    68
    17
    Default Checking Motor FIELD Voltage: VDC
    My Monarch Documentation Package shows the following on the full size wiring diagrams:
    Voltage Table:
    Can I check the Field voltage off the Terminal Strip on the module shown below?
  20. #18
    Mar 2016
    Louisiana
    437
    220
    79
    Voltage Table:
    Yep you can check it there.
  21. Likes Mac007 liked this post
  22. #19
    Jun 2009
    Kentucky USA
    127
    68
    17
    Results of Testing:
    First Pic is SetUp for Testing Motor Field From -18 & +F2 per the Monarch Documentation Using the Terminal Strip on the Tilt Out Modular Drive Panel.
    After Start up Read 118.8 VDC at -0- RPM, and 119.3 at 200RPM
    And 64 at 2000RPM and then after speed it up and back down it was 54.98 at 2000RPM.
    Monarch Says it should be 120 VDC at 200 RPM and 57 VDC at 2000 RPM
    So what should I check Next ??
    Thanks Everyone for you Help
  23. #20
    Mar 2016
    Louisiana
    437
    220
    79
    Looks Good On the field check. Next check the amps on the motor how much it is drawing when not cutting.
  24. Likes John S01 liked this post
