rcn11thacr
- Dec 5, 2019
I recently purchased a Monarch 10EE long bed and have been going through the steps to make sure she is in running order. It is a 1965 model sn#46154, Fuji VFD, 7.5hp, taper attachment, ELSR, and it has the 3 sight windows on the headstock.
The far left sightglass was hard to see so I took it off and cleaned it up. While I did that I noticed it is low on fluid and the fluid is In need of replacement. It’s old and grey looking with super fine grime in it (the reason why I could not see in the window clearly).
A) How do I properly flush this out? B) How much fluid does it take? This is for the gearbox. Thank you I’m advance for your help
