John Bakker
- May 12, 2020
From what I've found so far, I think it may be a 1909-1910, because the identification numbers are stamped between the ways, as apposed to being stamped on the flat tailstock way. The other thing that I have not seen before, is the way the lead screw support bracket is attached, using bolts from top down, rather than horizontally into bed.
The legs, lead screws and the apron did not come with this lathe that I bought for $50. I was able to get it running, and with the tool post I made, it takes a 0.040" cut on steel with no problem.
Sent from my LM-G710 using Tapatalk
