lectrician1
Hot Rolled
- Mar 6, 2012
- Las Vegas
I put a jones rpm meter at full speed reverse and it read 3800 just before the meter flew out of my hand and practically exploded. So no more testing with that meter.
In forward the lathe will only spin 2750
Anybody know why or what I could check
Or remedy the 1000rpm difference between forward and reverse
I have a 1955 wiad 10ee
Also if I put the drum switch in reverse while the spindle is still rotating in forward the contactor Sparks and the ffr relay drops out. The spindle must be completely stopped to put it in reverse
Sometimes if the spindle is moving in forward and I switch it to reverse, it will go in reverse for half a revolution then it will start spinning in forward then ffr relay drops out amidst some sparking from the reverse contactor
Any suggestions?
Thanks in advance
Rich
Any suggestions?
Thanks in advance
Rich
