Results 1 to 7 of 7
11-14-2019, 09:29 PM #1
i need variable speed rheostats from a monarch 10ee MG
i need the rheostat for an MG 10ee
i need the one that is towards the front of the machine but i will buy the whole assembly
PM me if you have one
Thanks Rich
11-14-2019, 09:50 PM #2
whats up with yours? I've documented 2 different varieties of these, but there may be more. What is your machine?
11-14-2019, 10:04 PM #3
mine has a few broken wraps and it is causing havoc with starting the machine. My machine is a 1945 MG 10ee
where can i see your description of the two varieties so i can determine which one i need?
11-14-2019, 10:45 PM #4
Not sure there is any difference to the lowly electrons, so long as it is an "MG" machine, 3 HP "large frame" 670 RPM base, 2400 RPM with 400 Ohm's series into the field - or so the dataplate calls for - UNLESS the motor has the rare 230 V DC field, or even THEN?
In any case, if motor has the common 115 VDC field, colour it "problem solved".
Just did an inventory, I have two of them.
One is on a promise before the aftermath of an accident laid me low AND a "ban" lost me the PM-PM correspondence as to WHOM I had committed it to.
The other one is for-sure spare, PM has my email for those who do not already have it, just click the userid and use the menu feature "Send Email".
The PM-PM box is ALWAYS full. And will be. Too much hassle to empty it.
Whom visits here and does NOT have email, anyway?
11-14-2019, 10:47 PM #5
PM me your email and I'll send you some info. The two varieties I documented were from an earlier inline 230 VDC exciter and the other was from what I would consider a more conventional 115 VDC piggyback exciter which came out of a 42 ish round dial MG (I forget exactly the year at this moment)
11-15-2019, 05:47 PM #6
That reminds me that the question had come up in another thread as to whether there were more than two different resistance zones used.
I had "planned" to print-up a "degree wheel" and plot a graph off the two sets still here - both ex 115 VDC "round dial" MG.
Meanwhile, side emails & c., lectrican1 has patched his one with some bits of Copper.
His 10EE now starts from any position, and adjusts speed well-enough.
Some days enlightenment can happen even in a dark room.
11-15-2019, 07:10 PM #7
Thanks for everyone's assistance.
I got my rheostats working
And I have a fair offer for a set from Thermite.
Thank you ALL
Rich
