My new 1977 10EE is a dream come true. Cuts perfectly. No wired chatter, vibration, or inaccuracy during heavy & light cuts. Threading is unbeatable.
THAT SAID:
It randomly lets out a little, tiny, short lived metallic squeak. Chirp/squeal/squeak lasts maybe .25 second, then a quieter short squeak after that. Maybe 3 or 4 of these chirps and sound is gone for an hour or more. Most often happens after stopping & starting again.
The focal point is right at the front spindle plate. Exactly where the front bearing sits.
Again, the machining is a dream! No “bad spindle bearing” issues of any kind show in the work this lathe can produce.
BUT I think that noise means take the spindle out & take a look.
I keep thinking it’s a sound resonating from belts, back gear, apron, gearbox...
But it cannot be. The squeak is most clear and loud right at the spindle nose.
Surely I shouldn’t use the lathe until I tear it apart! But that isn’t the answer I want! Is there any possibility of that noise coming from the tacho gear, or clutch dogs??? I know, prolly not.
I couldn’t resist asking.
I have flushed the headstock but will clean it again.
I want soooo badly to hear “just ignore the infrequent, VERY short-lived squeak”. I fear that isn’t going to happen.
Any help/scolding appreciated.
