Looking at a Monarch model.60 lathe
Results 1 to 6 of 6
    Oct 2008
    Conyers GA
    187
    5
    8
    Default Looking at a Monarch model.60 lathe
    Im looking at buyong a model 60 Monarch lathe. 20x120 built in 1956. 10 horse spindle motor.
    Any idea on the weight of the machine?
  2. Likes Baitshop liked this post
  3. #2
    Aug 2012
    California, Central Coast
    5,507
    2434
    2314
    As a guesstimate I would think around to 12,000 lbs. The info is in here if you can find it in a search.
    May 2020
    Indiana
    309
    83
    140
    If you dig into the publication reprints (search for Monarch first under the 'manufacturers index') on vintagemachinery.org, you can find a lot of information on these machines, including weights. You may be able to find series 60 specs, if not for that exact year.
    Monarch Machine Tool Co. - Publication Reprints | VintageMachinery.org
    Feb 2002
    New Mexico
    6,084
    63
    651
    For the Series 61 (very similar construction) the brochure lists 8160 pounds for the 48" model and 490 pounds for each additional 2 feet, plus 350 pounds for each additional leg. So maybe 9980 for a 3 leg 120" Series 61 and something very close to that on the Model 60.
    Feb 2010
    Illinois, USA
    688
    29
    209
    My 1957 series 61 is a 16" x 54", and it weighs exactly 10,000 lbs.. A 20 X 120 is going to be significantly higher, probably closer to 14,000 to 15,000 lbs would be my guess. 61's and 60's are very similar.
    Oct 2008
    Conyers GA
    187
    5
    8
    Lathes were delivered June 10th. Got them positioned in my shop safely. The Monarch came with change gears for metric threading and has a 2nd thread chart for that. Taper attachment too.
    The other lathe is a Prentice Brothers lathe. Probably from the teens. Needs some repair. Mainly the shift fork so I can use the four higher spindle speeds.
    Attached Thumbnails Attached Thumbnails 0610211027_hdr.jpg   0610211946.jpg   0627211841.jpg   0611212158.jpg   0611212209_hdr.jpg
  8. Likes TheOldCar liked this post
