rich hutch
- Nov 23, 2020
Hi all.
I just acquired a Monarch 10EE (July 1944 MG unit). The back story- I got it from the grandson of the previous owner, He said that everything worked but it had been sitting for several years as his grandfather health declined.
When I got it the AC motor started right up, but the DC motor does not respond. So I started looking for loose connections and found a wire attached to a relay in the DC panel (I think it is the FL relay) which makes sense with the symptoms.
Can anyone tell me where the wire should be connected?
Assuming this does not fix the problem, it looks like I need to dig into the diagnostics. I found several threads on this site, can anyone recommend the best thread to start with?
Rich
Rich
