Mg drive problems
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Aug 2004
    upper michigan
    352
    40
    Default Mg drive problems
    Hi all, I purchased a square dial mg 10ee a couple of years ago from a fellow pm member who purchased it from some unknown individual.
    Well the machine had a few mechanical issues broken missing parts etc, and electrical issues, lately I have had some time to mess with it, when I first got it one of the reostates had a open in it I was able to source one of those, and after looking through past threads found out it had a couple of bad resistors, I replaced those this week.
    So this is how the drive acts currently, when you turn up the speed knob the speed changes slowly upward till you get to about 2/3 of its travel then after that it rises quickly, till about 1200rpm then it lazily rises to its max of about 1500 rpms after several seconds of the pot maxed out.
    When you turn the knob down fairly quickly speed will drop to zero then back up to speed where the pot was left oscillating the speed up and down till it stabilizes.
    I have tried different brush timing on the motor (brush holder was loose btw) to gain rpm.
    Voltage between a1-a2 seems low maxing out at 180 volts
    This machine is missing its exciter, some previous owner added a transformer to the back of the machine, some kind of rectifier and a variable resistor on the ac side, 120 volts ac coming in 110 volts dc coming out, I tried bypassing the resistor but still have 110vdc coming out.
    Any of this give clues what could be wrong with
    1. Lack of speed
    2. Rise of rpm not linear on speed knob
    3. Osillation of speed when slowing down
    Any help would be appreciated
    Mike
    Sep 2002
    Arizona
    4,032
    1029
    621
    Quote Originally Posted by Mike Hill View Post
    1. Lack of speed
    Mike
    It sounds like you've got issues with one or both of the rheostats. You said that you sourced a new rheostat. 10EE motor/generator (MG) rheostats are specially wound; unless you got the right 10EE rheostat it probably won't work correctly. For example, the rheostats from a round-dial MG machine, especially a 230V exciter machine, could be a problem.
    The first thing to do is to check that the spindle motor and generator field voltages are changing as expected when you vary the speed control. The motor field voltage should be 115 VDC during the first half of the speed control knob's range, then decrease steadily to about 40 VDC as you reach maximum speed. Measure the motor field voltage between terminals F2 and E1 at the bottom of the DC control panel. The terminal numbers should be marked above the terminal. Always verify that you're on the correct terminal by checking the metal tags on the wires. The 110 VDC "exciter" voltage that you report is a little low, but shouldn't be low enough to cause major problems. What make/model meter are you using to measure the voltage?
    The generator field voltage controls the output voltage of the generator and thus the spindle motor armature voltage. Measure the generator field voltage between terminals GF2 and E2, at the terminal strip on the front of the MG. The voltage should be close to zero at minimum speed, then steadily increase to 115 VDC when the speed control reaches the midpoint. It should remain at 115 VDC for the second half of the speed control range. When the speed control is at the midpoint, the generator should be putting out at least 230 VDC (GA2 to GS1) and the motor itself should be turning at 690 RPM (the spindle RPM will be higher, depending on the belt ratio of your machine).
    I've not encountered the oscillation problem that you describe. See if any of the relays in the DC control panel are cycling when this is going on.
    Cal
    Aug 2004
    upper michigan
    352
    40
    The readings are as follows
    At max speed
    1. ga2 to gs1=174 volts
    2. gf2 to e1=.07 volts
    3. gf2 to e2=109 volts
    At min speed
    1. Gf2 to e1=105 volts
    2. Gf2 to e2=4.3 volts
    Readings were taken with a model Fluke 115 meter
    Sep 2002
    Arizona
    4,032
    1029
    621
    At max speed
    At min speed
    The generator field voltages at each end are as expected. However you haven't told me what's going on with the spindle motor's field (F2-E2). I need to know what's happening to the generator field AND spindle motor field at the midpoint, which is where the drive switches from "normal" (full field, variable armature voltage) to "field weakening" (full armature voltage, variable field). You also need to look at how the voltages are changing through the entire speed range, as discussed above.
    At maximum speed, with the 109 VDC on the generator's field, it should be putting out at lot more that 174 VDC (assuming that the M/G is running at full speed--it shouldn't slow down for any reason). The last time we saw something like that was a generator that had apparently been rewound and had it's shunt and series field windings connected improperly. Here are several of the more important posts from that thread:
    Disconnect the wires from your generator's field windings at the M/G terminal panel and measure the winding resistances: GS1 to GS2 and GF1 to GF2. Please post a photo of the M/G terminal panel and some photos looking into the the end of the generator, so that I can see what the coil wiring looks like.
    Cal
    Aug 2004
    upper michigan
    352
    40
    5bdd5f67-2e77-4d0d-adb7-21c13f4934fd.jpg7ce2c90b-222a-4b78-9b27-60a61694f1eb.jpgd164673e-ed3c-4ec0-b696-b2a467f5df15.jpg
    Thanks for the help Cal
    Aug 2004
    upper michigan
    352
    40
    Aug 2004
    upper michigan
    352
    40
    The unfortunate thing with this lathe is I have no idea what the previous owner of this lathe did to it, you can see they took some time to prep and paint the lathe and did a decent job but there was a lot of things partially done, along with broken and missing parts.
    Sep 2002
    Arizona
    4,032
    1029
    621
    Someone has definitely been futzing with your generator. That variable resistor doesn't belong there. There's normally a variable resistor located in the generator end-bell, but it's connected to the exciter, not the generator. Your generator's commutator looks a little dark and might need to be touched up with a commutator stone. Have you checked the generator's brushes?
    1e47cc71-997b-4b92-82b5-acac846b8abd.jpg...
    That's a very professional looking exciter replacement. The thing in the upper right corner, above the meter, looks like it might be a variable transformer instead of a resistor. Can you find a data tag on it anywhere?
    I don't know what's going on with your photos, but they are really low resolution. Are you using an iPhone?
    Cal
    Aug 2004
    upper michigan
    352
    40
    I took the photos with my I pad
    Aug 2004
    upper michigan
    352
    40
    The brushes look fine and move fine in their holders, the machine is at my shop so I can get the rest of the info tomorrow, I will try to get better pics with my phone.
    Thanks again Mike
  11. #11
    Sep 2002
    Arizona
    4,032
    1029
    621
    For some reason, iPhone/iPad photos come in a very low resolution. Try running them through a photo editor. A while back, member sent me some iPhone photos, I had save them to another format, then convert them back to JPG to get them to post at a decent resolution. I've tried to get the Forum Lords to look into the problem, but so far, no joy.
    Cal
  12. #12
    Virginia
    20,149
    7561
    11991
    Quote Originally Posted by Cal Haines View Post
    Pretty sure it is a Variac, yes. Now... nominal 115 VAC, rectified, holds-up nominal 90 VDC. Some of the most "common" variacs / variable autotransformer winding (I have 3 here, plus a BIG bugger for 240 VAC) were good for a boost from 115 VAC to around 130 VAC. That fits his 109 VDC after rectification pretty well.
    But may also be already maxed-out as to adjustment? It that IS a Variac, it is a right TINY one as such things go.
    Transformer "may" have a more useful tap? Label looks good.
    Higher-res photo, AND/OR/ELSE "also" .. maker, P/N, specs text copied and posted as text, there may be a way to get that Field Power up another tad.
    Pure guess, but it may not have enough current capacity to hold-up to the load of the combined field coils plus the contactor and relay actuator coils - hence the sporadic actuation?
    About a hundred bucks, a packaged nominal 180 VDC-out DC drive driven off 230/240 VAC input, dialed-down to 115 VDC (or the 140 VDC I use) and that whole rig is side-stepped.
    "If need be".
    One gets lucky, there is still some room left in the range of the Variac? Flick of the wrist, erratic operation goes back in its box.
  13. #13
    Aug 2004
    upper michigan
    352
    40
    F2-E2 is 107.5 at exactly mid crank of the reostate only spinning at 150rpm
  14. #14
    Aug 2004
    upper michigan
    352
    40
    Gs1 to Gs2 .4 ohms
    Gf1 to Gf2 351 ohms
    Leads were discontinued
  15. #15
    Aug 2004
    upper michigan
    352
    40
    I decided to throw caution to the wind and bypass the resistor on the end bell of the generator, the machine performed much better ran at about 2400rpm smooth speed increase from low to high on slow down speed would drop right down then come back up to the new lower rpm, only concern would be I could smell something getting warm and had excessive sparking on the motor comm
  16. #16
    Aug 2004
    upper michigan
    352
    40
    BY the way Ga2 to Gs1 was around 230 volts with the resistor bypassed at wide open
  17. #17
    Sep 2002
    Arizona
    4,032
    1029
    621
    Gs1 to Gs2 .4 ohms
    Gf1 to Gf2 351 ohms
    GS resistance sounds OK.
    GF resistance is high. Willray had a similar reading; it turned out that the generator windings had been improperly connected:
    You should check for shorts between each winding and the case as well.
    I'm surprised that you're getting full generator output / armature voltage with the exciter voltage and generator field resistance that you're reporting. Best thing is to really dig through Will's thread and sort out what's going on with your generator windings.
    The "something getting warm" smell may be related to the sparking on the motor commutator. There should only be a tiny pinpoint of light at each brush, no sparks. You should go back and check your brush contact and timing.
    Cal
  18. #18
    Aug 2004
    upper michigan
    352
    40
    Cal the “throwing caution to the wind” part came after I took the readings I reported
  19. #19
    Aug 2004
    upper michigan
    352
    40
    The resistor I bypassed was the one you questioned in the picture of my generators end bell
  20. #20
    Sep 2002
    Arizona
    4,032
    1029
    621
    Was the GF1-GF2 reading that you posted with or without the resistor? If it was with the added resistor, what is it without?
    Cal
