Mg drive problems - Page 2
Likes Likes:  0
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Virginia
    16,238
    7561
    10824
    Quote Originally Posted by Mike Hill View Post
    The resistor I bypassed was the one you questioned in the picture of my generators end bell
    Check something "basic", if you could.
    - Field power is coming off a packaged rectifier. I'll presume "full wave".
    One of their failure mode is to lose a Diode in one leg. Which leaves you with HALF-wave rectification.
    And can drop power enough the relays and contactors will not hold-in.. nor the Primary generator's field have enough power to produce full Armature output.
    "IF so"... then about a six-dollar FWB replacement might do yah?
    Just a thot'
    And drop
  2. #22
    Aug 2004
    upper michigan
    332
    30
    Cal the Gf1-gf2 reading was with the resistor, I failed to check the reading after the resistors removal😞
  3. #23
    Sep 2002
    Arizona
    3,864
    1027
    554
    Cal the Gf1-gf2 reading was with the resistor, I failed to check the reading after the resistors removal
    Check it now. If it's around 100 Ohms, you're good to go. I guess that someone wanted to limit the top speed of the machine for some reason. I think you said that one of the rheostats was bad when you got the machine, perhaps it's related to that.
    Cal
  4. #24
    Aug 2004
    upper michigan
    332
    30
    Gf1 to Gf2 ohm reading with the resistor bypassed is 93 ohms, your a steely eyed missle man Cal, good eye.��
