Model A carriage parts
W0CES
Oct 29, 2019
I have a Model A at work I was going to rebuild for a winter project. we only really use it for turning nylon bushings for some equipment. the carriage has a lot of play in the gibs is there a source still for those? it doesn't have a serial number it has a lot number of 243 No. 1
Any help would be great thanks.
If there is so much wear that the gib at full adjustment does not reduce the clearance to zero, then either make or have made a new, thicker gib..
Or, as I found on a very worn lathe: take a 12" long feeler gauge and put in beside the gib to take up the wear. It sounds like a 'hack' way to accomplish reducing the clearance. BUT, it must be a well worn machine, so unless you are going to go through the time and expense of regrinding the ways, the dovetail on the saddle and compound etc, then take up the clearance with a hard shim: aka: feeler gauge stock..
You can take normal length feeler gauges and try various thicknesses until you find one that will work then buy a full length piece of feeler gauge stock. Most tool retailers have individual 12" feeler gauge in various thicknesses, and I know feeler gauge stock can be bought by the roll, I have .005" and .010" in a roll. I'm surprised how often I use the material as shim stock.
DualValve
