Monarch 1000ee Questions and Handle Replacements
alcro1998
Cast Iron
Nov 10, 2020
Central Ohio
So, I have recently acquired a Monarch 1000ee. The lathe seems to be in great shape and I can’t find any major issues with it. The ways seem great and I took a peak in the headstock and all the gears look fantastic.
The lathe currently has a solid state DC drive in which I believe was installed by Monarch in the 80s. I can not run the drive at my shop but I was told it does not work. I might do an AC conversion but that will be saved for a different thread.
Now before I start digging into the machine too much there’s a few things on the surface that I’d like to address. The first being the issue with the thread selector.
When the thread selector dial is turned all they way to the right or the left to select the appropriate column to binds and will get stuck. I am not sure what is causing this but I’d assume the selector is very similar to a square dial 10ee. All the other thread selections work fine except for the far right and far left. I took the thread chart plate off and can’t seem to see anything binding so I am at a loss. I thought it would be the rack to move the Spector back and forth but can’t see any visible damage or anything that would cause the binding.
The next 2 things are the tailstock and apron hand wheels. They were both broken at one point and the tailstock handle fell out while in transport. ��*♂️ I was wondering where to get these besides from Monarch or eBay and if they are the same as any other model of monarch. They looks similar to the 60 series wheels possibly. Everything the wheels were attached to seems fine and they still turn very smoothly.
The last thing is the cross slide dial and handle. The dial seems to need a bushing or something since it’s a little loose. Again this looks similar to a 60 series and I was just wondering what needs to be replaced. I haven’t gotten the screw off to look closer and will need to make some kind of spanner wrench to fit. The handle on the dial is super loose and will go in and out no problem so I’d like to replace that if I can. Luckily I noticed this before bringing the lathe home so I did not lose it in transit.
The last thing is the control panel on the headstock. It’s not like any other 1000ee I have seen. All the light on the right and buttons and the switches on the left are all potentiometers. None of them are labeled and the right switch cover things are all gone except the bottom one. No idea what they are for. Maybe for the constant surface speed? Not sure. It would also seem that this one is rated for 2500 rpm? I thought 1000ees only went to 2000?
Any help would be appreciated.
Thank,
Chris
I can't help you with any of that.... But I would like to say that you are one lucky son of a ... gun.. scoring a 1000EE Don
Thanks! It is quite the unit. Really makes every other lathe look tiny. The ways are MASSIVE compared to my Cincinnati haha.
Better pictures. Did not upload full resolution from my phone...
I have a 13EE and think you are correct that the standard tailstock shares hardware from series 60/61 machines. The carriage hardware as well where they were the same. I don't recall ever seeing that spindle control panel? The 13EE has a constant surface speed knob low on the headstock were your machine has the thread/feed selector. That panel replaced the knob? On the 13EE the only thing was the pot for speed, all the other functions were on the carriage control panel. The 13EE has six potentiometers on the carriage control panel.
A couple pics of the controls on both the carriage and headstock would help, along with the constant surface speed dial?
Steve
Amazing lathe, I gotta ask how you transported and moved it? I recall a reliable notion of 12,000 lbs.
That would be an overload on anything short of a tri-axle (6 tire) or a dual-tandem (8 tire) setup I'm thinking...
I saw a pallet jack but mine gets nearly useless over 3k, Machine skates are much easier to push I've found.
If your handles are the "thin rim" sand cast aluminum Monarch originals, I'd advise keeping those around as they are really nice to use. Focus on repairs, welding, sleeving, etc.
Hope you can get the spindle drive issues sorted out.
It sure is an amazing lathe! I am keeping the wheels around until I can replace them. They work fine but have a wobble to them.
The stand alone weight in the 13ee catalogue said it weighs 10,250. I have a no ramp trailer which is rated at 10,000lb payload. 2 7k axels and the trailer weighs about 3600lbs.
Items used for loading- No Ramp Trailer u-14, pallet jack, 2 forklifts.
1. We forklifted the lathe outside of the shop.
2. While the lathe was lifted a bit, I lowered the trailer some and backed as far under the lathe as possible. Trailer ramp was maybe 12 inches under the lathe.
3. We lowed the trailer all the way and positioned the pallet jack as close to the end of the ramp as possible.
4. I jacked the pallet jack up till it started lifting a bit and the second forklift picked up the tailstock end.
5. The first forklift then set the lathe down so the fist 12 inches of pallet jack and second forklift were supporting all the weight. (Very scary at first!)
6. Once on the trailer enough to get the pallet jack all the way under, we lowered the headstock end on 4x4s so I could move the pallet jack up to distribute the weight on the pallet jack more.
7. Once in this position, the forklift pretty much just pushed it all the way onto the trailer. I bit of adjustment of the forklift forks were needed at the end so it could push the lathe all the way onto the trailer.
8. We set the lathe on some 4x4s going length ways to support the lathe all the way.
9. I lifted to trailer into ride position, strapped the lathe down and drove the 4 hours home.
UNLOAD- I hooked the winch to the lathe so it wouldn't run away and we used 2 pallet jacks to roll it off and into the shop. Took some time and a lot of pushing but my buddy and I managed to get it done. With the lip at the shop door and the no ramp trailer the incline is super gradual so its pretty safe for us and the lathe. Once in the shop we took the 2 pallet jack and pushed it against the wall.
Added note: WE kept 4x4s under the lathe most the time loading and loading and just hovered the lathe over the 4x4s while moving. This was so if anything gave way the lathe would just land on 4x4s.
All in all it work amazingly and I would do it again.
Here is the picture again. You can get the idea of how we unloaded it a bit better.
Steve
This is all the control the lathe has... Not sure if the headstock controls are supposed to be for CSS or not. Was CSS an option or did it come standard. Maybe mine does not have CSS. I will call Monarch this week too and see what they can tell me. Seems like every 13ee/1000ee/Model 71 I have seen is very different.
Also do you have any idea why the threading would bind up bad at columns that thread 64 and 120? Every other thread works fine. The last pic is a pic of the threading area but I am pretty sure this is the same on every machine.
Not sure on the thread issue? Bad registration of the gate?
Is there a meter under the tach that says surface speed? The 13EE is electro-mechanical with constant surface speed, it used a pot at the headstock to set the major diameter RPM. The crossfeed has a coupled geared pot that moved with the crossfeed screw to change the speed.
Remember the 13EE debuted in the early 50's but was engineered during WWII and just after.
Where are you in Ohio?
I ran a 1000EE at a previous job, and my friend now owns it. It becomes mine when he retires. It's still running and hard turning to this day. Original drive.
1000EE's are rare, but if yours has threading, it is far beyond rare. Unicorn status.
The 1000EE I ran at the previous job, I intended to buy, but wasn't gung ho about it since it did not have threading. I called and talked to Monarch and I don't remember the exact numbers, but it was something like they made 50 1000EE's without threading for the US Government and TWO with threading.
First thing I would do is call Monarch and ask them to pull the file and send any information they are willing to send.
The lathe currently has a solid state DC drive in which I believe was installed by Monarch in the 80s. I can not run the drive at my shop but I was told it does not work. I might do an AC conversion but that will be saved for a different thread. ...
Nice lathe and creative approach in moving it.
I was curious about how Monarch approached the spindle bearings on those machines. Do you know whether they were angular contact bearings or tapered roller? Also, what was the arrangement of the spindle bearings?
If you convert it to a VFD, how many horsepower would that be and how much room in the machine is there? Anyway, great find!
I am in Sunbury, Ohio. Its about 1hr 45mins from Medina. I seem to go up there quite a bit since there is a lot of stuff for sale up there.
I thought every 13ee/1000ee/ Model 71 I have ever seen has had threading? Seems like threading would be standard for a best of the best lathe. Maybe they had the numbers backwards and there were only 2 made that could not cut threads?
I have no idea on how the spindle bearing are configured. I think there is an exploded view of the headstock in one of the manuals I got so that might clear things up.
My current plan is to use a 10hp motor. I talked with a guy who converted his and he said 10hp seems to do the job just fine. It has 3 geared speeds and open belt so you don't lose as much power as you would on a 10ee. There seems to be quite a bit of room in the base. The base goes all the way to the back of the electrical cabinet and runs the whole way along the base. The base is something like 40 x 105 so there is plenty of room for everything.
This picture helps show just how HUGE the base is.
As far as AC motor/VFD replacement. When I got my 13EE it had a 10 HP motor with a VFD the spindle/gear train seemed to overwhelm the motor. I replaced it with a 15HP inverter duty 1200 RPM motor and new drive. The 15HP is a much better match to the rolling inertia of the machine. In open belt the 10 was OK, with gearing it was not great.
Steve
May we ask if you had "utility-grade" 3-Phase, and were able to utilize a VFD without need of de-rating or special selection among those purpose-built for single-phase local power input?
Bill,
I have 480 three phase, the VFD is an 11 KW? No derate. I do have a 30KW inverter that could work on single phase with a 240/480 x-former. The current on that would likely be well above anything you could light off in residential service. I am not up on single phase input inverters at or above 4KW or so? In a residence a Phase Perfect of other electronic phase converter would be my choice to power a machine of this size. That would also require a strong main supply a shared 35KVA pole pig ain't gona cut it.
Steve
I am not 100% sure what I will be doing at the moment. Right now she's just looking pretty sitting against the wall. I do plan on moving shops in the future.
I moved into this shop on June 10th and this is the first time I actually have had space. Before this shop, the foot print of the 1000ee would have taken up about 50% of my square footage. This new shop is about 12x the space that I used to have. I still would like more space but this shop has been working out well.
I am thinking about buying a shop after I graduate but I also want to buy a house. Rent is also very reasonable where I am right now.
Decisions decisions.
I was looking at a 10hp polyspeed vfd and maybe if I do convert it and get more power at some point, I can use 10hp drive for a 10ee. Then I wouldn't have spent all the money for nothing. Assuming the 50amps I have will run the vfd.
I am also pretty darn sure the 1000ee I have has a 15hp motor.
It be helpful if you could post the serial number plate. Monarch made a lot of special "One-offs" of their standard lathes and sometimes you can pick that up in the serial number plate.
As far as I can remember threading was standard feature on 1000EE-Series 71 as it was to be a larger toolroom lathe.
John
Alcro1998... Yes I know this is a very old thread.
I have a 1961 1000EE still setup to run on DC via a Sabina solid state drive. However, it has not been powered up for 30+ years (Idaho barn find where it sat for decades, never connected to power). I'm happy to take photos and to supply other info for purposes of comparison. I'm able to do that now before moving operations 1500 miles east; this particular machine has not yet been loaded.
Given the passage of time, I'd be curious to know how you've made out. I read in other threads where you sort of parked the project while waiting to setup in a larger shop with more power. Did you ever manage to get her up and running? Original DC spindle motor with resurrected solid state DC drive or AC conversion?
The way things go, it is quite possible that you are still in a holding pattern (these things do take time)... My advice would be to keep an eye open for an old Detroit Diesel powered Delco 3 phase generator (the 3 cylinder 20kW version runs at 1200 RPM and is quieter and less stressed than the much more common 2 cylinder "Duce" variant which runs at 1800 RPM). Drive as far as necessary to bring it home; make sure it's eating all its carrots and peas then build a soundproof shed for it. They are extremely robust and will consume about 1 gal/hour if driving a lightly loaded 20 hp AC induction motor and it will start that motor without the slightest hiccup. It will also simultaneously drive single and 3 phase loads.
In my case, I've opted to attempt resurrecting the Sabina SS drive and would value input from anyone who's been down this road. If I get there first; I'll share what I will have learned.
I will attempt said resurrection once I get moved and unpacked. In anticipation of this, I contacted Sabina asking for info and was hoping they might supply a schematic but the person I spoke with was of no help and did not seem particularly motivated. The SS drive is in a large, stand-alone cabinet. The internals of the drive are pre-microprocessor era; all components are human-scale which in theory means it should be more easily repaired/diagnosed. All PC boards are built to slide-out for servicing. Before attempting to power it up, I will at minimum, replace all electrolytic capacitors and then ramp up 3 phase AC power slowly (via a DD powered 20kW Delco 3 phase generator that has fully adjustable output). Again, any advice from those with experience would be greatly appreciated.
According to Monarch, my machine was originally sold to Northrop Grumman and fitted with the Sabina DC drive in the 1980's (while still owned by NG). The last time it ran was when they still owned it.
Threads/Feeds Selector
If your threads/feeds selector is still hanging up, verify that the lock lever under the SF/Min. gauge (on headstock) is fully released before rotation of the threads/feeds selector and that this lock is fully releasing and locking correctly (pull lever out, toward tailstock then rotate). Note small and larger caps for oil located just above lock lever... Position of small cap suggests it might lube the locking mechanism.
Apron-Mounted Switches and Knobs
I've never seen photos of apron controls like those on your machine... With one exception, controls on mine correspond to photos in the factory brochure and consist of the following:
  • 2 large buttons labeled Start and Stop... What they start and stop is not clear. Spindle power? Constant SF/Min. function? The answer might be in the documents I have for the machine (already packed and loaded).
  • A 2-position rotary switch labeled "Spindle - Forward - Reverse".
  • A 5-position rotary switch labeled "Headstock Positions → Neutral + Low + Int. + High + Open Belt".
  • A multi-turn potentiometer labeled "Speed Control → Slow + Fast + Max Power" allowing infinitely variable speed control within each of the 4 ranges (see "Headstock Positions" listed immediately above):
  • At the top left should be the SF/Min. speed control. In the case of an update to solid state DC drive, this feature could not be accommodated. The "upgrade" to SS therefore comes at the expense of the 1000EE's best party trick. When the conversion was made on my lathe, the dial/knob for this potentiometer, as well as its label, were both removed (this is the aforementioned exception). The hardware beneath however appears to still be present, as do the associated mechanical linkages and solenoids inside the motor cabinet. Unfortunately, original associated circuitry in the DC drive cabinet will almost certainly have been deleted.
  • To the left, in a separate casting is a larger pull-to-turn/push-to-lock dial used in setting up constant SF/Min. A cast plate above it instructs the operator to position the cutting tool at the start of cut, note the diameter, then select the same diameter on the dial.
What would I not give to have all the original electronics? Today there are solid state replacements for the C16J tubes which, from what I understand, allow continued use of the original drive.
Weight
The data plate reads just shy of 12K lbs.
