Looking for help with my Monarch 10ee. I was drilling a hole in aluminum when it bogged down and it eventually stopped. It blew a fuse in the control panel. I then hit the reset button on the back and got the light to work but it continuous to blow fuses and it does not run.
The machine is a 1949 10ee with the original motor running 220 volt single phase with a VFD. It also has the LSR option. It was a good running machine up to now. Maybe somewhat limited because of the retrofit but it was good enough for me.
Any parts that I should replace or any help or advice will be welcome.
Thank you.
