Monarch 10ee breakers size - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Sep 2002
    Arizona
    3,448
    718
    432
    Agree. I was about to suggest that he measure the current on both legs and see what's going on. That motor should have about a 14A rating at 240V. Even if it's running at full load with a power factor of 0.8, that's still only about 20A. A typical 30A breaker can take 40A for a minute or more before it trips. So something weird is going on. Maybe a bad breaker or bad run caps?
    pier, Do you have access to a clamp-on ammeter? Are there fuses in power connection box on the back of the machine? Does the main AC contractor have overload protection?
    Cal
  2. #22
    Virginia
    24,082
    7561
    7499
    Quote Originally Posted by Cal Haines View Post
    donie, thermite, PLEASE lay off the bickering! You're not helping the community with this stuff.
    I went through the thread and deleted the off topic comments directed at each other. I saved what I could of donie's shop photos to Shop Tips and Project Photos
    I don't have time to sift through your posts and try to save the things that actually apply to the topic at hand, so when I see you guys going at it, I'm just going to delete the posts.
    Cal
    Thanks, Cal, sorry for the side-show - tried to mark those so outright deletion was faster.
    I've now put him on ignore, so the photos have ceased messing up the screen as well as the text.
    Back to the topic and the STRONG evidence from the report that this has NOT happened when running under loads light, medium, or heavy if even Pier has any truly "heavy" turning, so far.
    Pier had told us the problem is both random AND intermittent, and occurs ONLY while at idle when the MG's own current flow would be de minimus.
    That almost shouts out loud "external problem source" to me, and I hope Pier has gone scouting and even already found the perpetrator. De-powering various "suspects" to see if the problem at the 10EE's MG ceases whilst some other thing is off should be easy and "done already".
    'Scope needed only if the source is in a nearby home or shop - even just the other side of a demising wall in a row of shops.
    My small Campbell-Hausfeld air-compressor does nearly the identical dirty HERE, not to the machinery, but to same-family Square-D "QO" breakers sometimes, and GFCI outlets LOTS of times if I have it at work where I don't have a non-GFCI protected outlet.
    It is always on shut-off, never run nor startup, and only on "some" shut-off cycles, maybe one in five or eight - never all.
    I "should" fix that right ON the device - it is cheap and easy - but have been too lazy, given I plan a new compressor anyway.
    20CW
  3. #23
    Feb 2015
    CANADA
    Ontario
    28
    Hi CAL
    Right now I don't have a clamp Amp-meter that I could trust. My previous B&K 350B that I bought on ebay gave me wrong readings, so I am basically ignoring its existence.
    First, I want to point out that I did perform the single phase conversion on this lathe because I don't have three phase power here at home. I moved the lathe a couple years ago from the shop (in there we have three phase power), and then decided to re-conditioned, so I could use it at home for small projects. The conversion process was easy and smooth, including taking the stator winding out of the generator casing. That process also gave me a chance of determining the state of the wires and coils (which was very good).
    I was contemplating of buying an RPC to power up the lathe, but then decided not to, given that, "That's another unit running" and therefore, not being 100% efficient, will demand a bigger breaker circuit in the panel, and currently the electrical panel it's over his design capacity, so I need to be careful of what is being used at home before I turn the lathe on.
    The power quality in my neighborhood is very clean otherwise, there are no shops or other industries around my street that could make the grid fluctuate that much.
    Currently I am strongly suspecting that it is the breaker, but I don't want to replace it, unless I know for sure that it is the problem. This is the reason that I came to the web site to ask what size of breaker you require after the "Single Phase Conversion". I wish that some other people that perform that conversion will come forward and give their 2C. From my calculations, the 30 AMPs should be plenty, but who knows. In the shop when we had the three phase, the breaker size was 20AMP-3PH.
    Cheers
    Pier
  4. #24
    Feb 2015
    CANADA
    Ontario
    28
    Hi CAL
    One more thing that I should mention:
    What if the "SUPCO APR5" fails to disconnect the START capacitor, or it intermittently closes the contact due to some unknown reason, would this be a cause for over-current?
    I kind don't trust the source of where I bought that relay (again, on ebay) so that is another of my suspects.
    Is there a way to test the SUPCO APR5 relay by itself?
    Is the adjustable voltage on the SUPCO relay the rms or peak voltage? Currently it is set to 250 Volts (because the instructions said to do that).
    At one time I did notice the voltage across both the START and RUN capacitor to be very high, even after 30 seconds after power up, but I did not pay to much attention then, since things were running. But now, I find that to be abnormal because the voltage on the START capacitor should be zero after power up.
    I do trust the capacitors because they are from a local vendor.
    In my case I use 2 X 100uF-400VAC caps for the START (in parallel) and one 60uF-400VAC for the RUN cap.
    Cheers
    Pier
  5. #25
    Virginia
    24,082
    7561
    7499
    Quote Originally Posted by pier View Post
    Hi CAL
    Cheers
    Pier
    Pier. the 30A is more than adequate. On single phase a 20A is not quite enough - the MG's AC motor still has "inrush" S-H converted or not, and still looks much the same as any other motor starting load.
    If we had "all the numbers" you might need a 25.7 A for startng, but only a 16.4 A for running, etc. but 30A is fine. An SSD drive can actually be run with only a 15A breaker.
    OTOH.. this may sound bass-ackwards.. if you have even a 20A two-pole, do try that..
    If the 30A breaker is doing an internal stir-fry it will usually fail the "sniff test". Apply the nose when it is OUT and and and .. no longer on the leads, either.
    If the 20A does not trip-out at idle, THEN go and find a new 30A, and DONE.
  6. #26
    Sep 2002
    Arizona
    3,448
    718
    432
    Hi CAL
    If the potential relay fails to disconnect you'll know about it pretty quickly. Electrolytic starting capacitors can't survive very long when connected to line voltage.
    I don't see any discharge resistors on your capacitors:
    When the potential relay opens the starting capacitors will sit there with whatever voltage they had at the moment they are disconnected from power. You might want to put a 100k Ohm, 1 Watt resistor across the terminals of the start caps to slowly discharge them. (Note, it will take the resistor over a minute to discharge the caps). Check the voltage across the caps once they've had time to discharge. If you're still seeing line voltage there, then something is wrong.
    You should buy or borrow a clamp on ammeter to check the currents. You can get one from Amazon or HF for under $30 that will be good enough for what you need.
    Cheers
    Pier
    Peter's Stillman conversion diagram calls for three run capacitors (Cr and Cpf are run caps):
    What diagram did you use to wire up your system?
    Cal
  7. #27
    Feb 2015
    CANADA
    Ontario
    28
    Hi CAL
    I used the diagram presented by Flail in the Sticky thread above:
    "Sticky: Converting Monarch 10ee motor-generator 3-phase to single phase, Steelman method
    Started by Flail, 11-10-2013 07:50 PM"
    I did follow all his instructions as presented. I also, did find a mistake in his diagram which I reported it and he quickly replied with a correction.
    As far as my start capacitor, it is actually a "RUN" type (two in parallel to give a total of 200uF- 400VAC) so that they will last longer even if the potential relay is stuck closed.
    Also, this may be the reason that the voltage across these caps I observed originally is higher than the line voltage due to a Back-EMF" from the MG if it is actually running faster than the rated speed (when there is no load).
    I need to take the whole thing apart again and re-check everything rather than assume that everything should work.
    Is there a way to check each of the winding of the MG statically? to make sure that they are not damaged. If there was damage, would I have seen smoke or high temperature on the motor casing? How long would the MG run with high currents in the winding's?
    This one other though I had:
    Electrically, what if the Capacitive reactance is exactly the same (or close)to the inductive reactance (they will cancel each other), then the third winding would be only resistive (I measured about 7.2 Ohms with an Ohmeter) and therefore a large current will flow on this winding: 220 Volts / 7.2 Ohms = 30.5 Amps. This can also explain the breaker Poping when the MG is idling. This is making me re-think about selecting the right value of capacitors. Any thoughts on this one?
    Cheers
    Pier
  8. #28
    Virginia
    24,082
    7561
    7499
    Cheers
    Pier
    Pier, I don't THINK we have seen this addressed before now. I don't think it actually happens that way, but it is surely worth chasing up!
    What might it take to better "instrument" and record it that you do not already have?
  9. #29
    Sep 2002
    Arizona
    3,448
    718
    432
    Hi CAL
    Quote Originally Posted by Flail View Post
    So here is the schematic I drew up of my components. Wish I had something simple to draw up schematics with a Mac. The relay basically parallels the start with the run capacitor for a second until the motor comes up to speed. When voltage get to about 310 it drops out the start cap. As a fail safe it will also drop out after a short period of time 1-1.5 seconds. As a test I put the lathe in forward (DC motor turned on) and the motor started anyway. This suggests this is not an iffy conversion if the motor-generator can start with a load on it.
    For all those looking at this: Good catch by Pier. The 300uf capacitor goes to supco potential relay terminal #1 and the 60uf should go to terminal #2.
    reference: 404 Not Found
    Among other things, this converts the motor from Wye to Delta configuration. It then adds a start capacitor and a run capacitor to one phase only. I haven't taken the time to dig into the Stillman conversion, but at first blush, I don't see how the above design is ever going to be balanced. I think there's a reason the original design had run capacitors on each phase.
    I don't think this is a back EMF thing, but I could be wrong.
    Here's a post that walks you through checking the MG's AC motor windings.
    Wiring repairs for 1941 Monarch 10EE
    In your case, you have access to all six windings, so you can check each one individually. That is, (with all the leads disconnected) you should see the same resistance between leads 1 and 4 as you do between the leads for the other five windings. Also you should NOT see resistance between lead 1 and any other lead besides 4, and so forth, for the five other windings. None of the twelve leads should show resistance to the case of the MG. Even better, check each winding with a megger to make sure that the winding insulation isn't breaking down at high voltages.
    Cheers
    Pier
    I don't think that's it either, but I'm not at all sure what you've got going on here. I'll have to do some checking and get back to you.
    Cal
  10. #30
    Feb 2015
    CANADA
    Ontario
    28
    Hi CAL
    Yes, you are correct, this design is not balanced, but it is the reason that it will work. We need one unbalanced winding in order to generate the initial torque to get the MG going, then the SUPCO APR5 relay will disconnect the larger capacitor but keep one of the winding still out of phase (slightly) to generate a slipped torque in order to keep it moving. I think this is a simple design, and I have proof that it works, but there may be some issues in selecting the proper working conditions.
    I think Flail must have had some ideas from this site:
    23V & 46V Static Phase Converters | Manufacturer
    These people still make the static phase converters as you can see from their website.
    In any case, my priority now is to disassemble my MG and re-start from scratch, but this time I will measure and calculate every step of the way. I will first determine the health of the MG itself, want to make sure that I did not abuse it during these tests trials. I will then contact Steelman Industries and ask their opinion on the setup that is described here and above.
    I am wondering if Flail is reading this so that he can give me some of his inputs as well. I know that he made a video of his test setup, and that was the reason that I was hooked on this simple solution.
    On the weekend I will spend some time taking a number of readings on the MG winding resistance and insulation condition.
    Cheers
    Pier
  11. #31
    Sep 2002
    Arizona
    3,448
    718
    432
    I was incorrect. This is definitely not a Delta connection. You've got windings 1-4 + 5-2 in parallel with windings 7-10 + 11-8 across L1 and L2; that's the normal connection for those windings in a low-voltage Wye configuration. But instead of 3-6 connected in parallel with 9-12, with 6 and 12 connect to the star points of their Ys, they're connected in series: 12-9 + 6-3 and in series with the run capacitor. 3-6 + 9-12 is the high voltage connection for those two windings. So I have no clue what's going on here. If you have it figured out, great, but I'm not going to be of any help to you.
    Cal
