PWP
Hot Rolled
- Apr 1, 2005
- Bourbon, Missouri
Does anyone know if the ELSR casting at the right hand side of the
Bed functions or operates the three internal switches in the same sequence. I am comparing a 1974 machine vs 1959 machine, The newer machine makes no sense.. The 1959 will make contact with the upper switch tab in the forward direction with the lever on the carriage in the upper pos. in the middle, the two top switched do not make contact. Lower the carriage direction lever, and the middle switch makes contact. The lowest switch is triggere in the forward and reverse position. Hope this makes sense.
The 1974- No where near this operation. Can someone open up the cover an a modular ELSR and let me know if it functions the same as the 1959 mode.
Paul
Paul
