Hobby Racer
- Apr 18, 2015
I have a 1942 Round Dial MG + Piggyback with the Reliance large frame 3hp spindle motor and my DC control panel looks much like this one, but mine is missing the Fwd/Rev contactors entirely. In looking for a replacement I am trying to better understand the OEM function and construction. Reading the schematics and other forum posts I believe the labeled contactor functions are as follows (please correct me if I have it wrong).
Looking at just the forward contactor:
A = A1 armature contact
B = A2 armature contact
C = F1 field contact
D = F2 field contact
E = A1 armature connection to the dynamic braking resistor
A,B,C,D are normally open and E is normally closed. When the contactor is closed those are then reversed.
Assuming that's all correct, I have some questions that maybe you can help me with.
Any insights will be helpful.
- Why do A,B,C have arc chutes under the contacts and D & E do not?
- Why is there no barrier between the contacts of C & D like there is between A,B,C?
- What is the function of the coils of wire under the contacts of A,B,C and why no coils under D & E?
- Why is the wire diameter of the coil under contact C so much thinner than the coils under A & B?
- During operation, how much voltage and current can be expected across each contactor when making or breaking the connection?
