Monarch 10ee gearbox lever seals
Results 1 to 7 of 7
    Jan 2013
    New England
    112
    23
    15
    Default Monarch 10ee gearbox lever seals
    Trying to change out and order the seals. I have the gearbox / feed / thous lever ready to come off but it won't budge.
    Is there a tutorial ?
    Sent from my SM-G950U using Tapatalk
    Jan 2013
    New England
    112
    23
    15
    Found the additional set screw on the bottom under years of paint.
  3. Likes Zap921 liked this post
    May 2009
    Canandaigua, NY, USA
    3,440
    181
    1777
    Yep, the old hidden-under-the-paint screw trick!
  5. Likes Jaymce, Yan Wo liked this post
  6. #4
    Jan 2013
    New England
    112
    23
    15
    Just to update
    I solved the leak on the feed / slip gear lever with skf part # 9878 McMaster Carr # 5154T36 and a square o-ring McMaster Carr #4061T228 to add to the packing.
    On the thread Selector knob I used SKF# 4985 McMaster Carr # 5154T32
    I also replaced the gaskets on the sight glasses that were weeping and used a little thicker material which allows me to see the level of the oil more clearly.
    I believe the leaks on the front of the machine have now been cured.
  7. Likes Colt45, Zap921, rakort, TheOldCar liked this post
  8. #5
    Jan 2013
    New England
    112
    23
    15
    Turns out the seal on the belt feed/ gear thread was also leaking. Same seal as the thread feed seal. 1" od .500" id.
    Sourced locally Timken # 471442.
  9. Likes TheOldCar liked this post
  10. #6
    Oct 2018
    Ohio
    254
    224
    44
    Great info and glad you got it. Thanks!
  11. Likes Jaymce liked this post
  12. #7
    Sep 2002
    Salinas, CA USA
    4,875
    550
    456
    I just ordered all three seals from Monarch. About $60 for the three.
