Monarch 10ee metric change gear set
Results 1 to 17 of 17
    Mar 2015
    Montana
    23
    Default Monarch 10ee metric change gear set
    Does anyone have any information about how to set up the change gears for metric threading?
    I have a 1952 10EE that was sent to Monarch in the 80ís for a complete rehab.
    I took the cover off the change gears and I believe the 127 tooth gear is in there. And I have a box full of other smaller gears. I just donít know how or what else I need to set it up.
    There is a factory plate mounted on the machine for metric threading settings. See pics.
    Sorry about the pics. Canít figure out out to rotate them.
    Randy
    Apr 2010
    Wisconsin
    6,168
    4235
    3854
    Shoot me an email through the forum's email function and I will send you the PDF instruction sheet that we include with our Monarch 10EE Metric Threading Change Gear Kit. It's really rather simple.
    Jun 2007
    Nevada
    552
    73
    Apple has a an issue with the pics not rotating properly. Here is a solution. When I download pictures from the iphone or ipad to the mac I then duplicate the picture (right click, duplicate) delete the original, and open the duplicate picture in preview, then rotate the picture left or right 90 degrees and back to the orientation you want, and hit save. It will then load properly in posts. Sounds like a big nuisance, but you get used to doing it.
    Jun 2007
    Nevada
    552
    73
    ZK's instructions should explain all, look at my pics and explanation here as well.
    Metric threading gears - 10EE square dial
    Jun 2009
    Kentucky USA
    127
    68
    17
    I’m lacking the 50 & the 75 to have the complete set.
    Jun 2007
    Nevada
    552
    73
    ZK can make them for you, or if you buy me a hob I'll make them. I still haven't been able to find a 32 Dp 14 1/2 PA hob on ebay. Just got a beautiful brand new Gleason 36 Dp hob for $25, though.....
    Mar 2015
    Montana
    23
    Zahnrad I’ll do that, Thanks
    Jun 2016
    New York
    1,887
    1220
    898
    Quote Originally Posted by bll230 View Post
    there is an easier way; just select the image you want on your iOS device (actually, I've only done it on the iPhone ), hit "edit" and rotate the image (I just hit it 4 times for a full 360). thats it. no need to duplicate or delete anything. there is some additional orientation information added to the file when you do that, and it stays with the pic.
  9. Likes bll230 liked this post
  10. #9
    Jul 2011
    Utah
    1,001
    2224
    410
    Quote Originally Posted by Mac007 View Post
    If you’re interested, I have an incomplete Monarch set that came with some parts I bought; I can check if I have the 50 and the 75.
  11. #10
    Jun 2009
    Kentucky USA
    127
    68
    17
    The Metric gear set I received with my 10EE are NOT helical gears, they are straight toothed. Iím thinking I can use my Horizontal Mill and My Dividing head to make the 2 missing gears from this set, the 50 & 75 tooth.
    Does anyone know what the DP is for these gears? I am assuming the DP is the same for all the gears in the set and the only change is the Diameter of the gears increases as the number of teeth increase. I donít have a Gear Gauge set or I could perhaps determine this on my own.
    EDIT: I found another post that shows the gears are 14.5 PA, 32 DP.
    Or perhaps someone can simply tell me what involute Gear cutter(s) I will need to cut the 50 tooth and the 75 tooth gears?
    Kind Regards, Ken
  12. #11
    Jun 2007
    Nevada
    552
    73
    32 Dp 14 1/2 PA #3 for the 50 tooth,
    32 Dp 14 1/2 PA #2 for the 75 tooth
    Outside diameter is N+2/Dp
    cutting depth is what is marked on the cutter or Dp/2.157 or Dp/2.25 depending on manufacturer.
    Travers has these Chinese ones for $50 each or you can buy higher quality from Ash Gear, don't know the price from Ash. Gears are an expensive hobby.
    TTC 32 D/P x Cutter # 2 14-1/2deg PA HSS Involute Gear Cutter | eBay
    TTC 32 D/P x Cutter # 3 14-1/2deg PA HSS Involute Gear Cutter | eBay
    edit: depth is 2.157/Dp or 2.25/Dp. inverted it above.
  13. Likes Mac007, TheOldCar liked this post
  14. #12
    Jun 2009
    Kentucky USA
    127
    68
    17
    BL230,
    Thanks for the info, greatly appreciate your taking the time to post
  15. #13
    Jun 2009
    Kentucky USA
    127
    68
    17
    Looks like with a DP32, 14.5ļ PA Cutter #2, & #3 you can cut all 8 gears in the set.
  16. #14
    Jun 2007
    Nevada
    552
    73
    You do not need to make both gears. If you do have all but the 50 and 75, the only pitch in use you do not have is 1.25 mm. You only need to make one of the gears to get 1.25.
    Email me and I'll send you my complete metric thread spreadsheet.
    John
  17. #15
    Apr 2010
    Wisconsin
    6,168
    4235
    3854
    John
    My understanding is that he wants to recreate the Monarch set so as to "have the full set". Back in December, I had offered to make him the two gears when we make more Kits**, but never heard back from him.
    ** - scheduled, but not started yet, for being busy with other work.
    I'm assuming that he does not wish to wait for generated gears that match what he has, and wants them for some impending need. Otherwise, I'm not sure why someone would want to mix form milled ones with the Monarch ones.
  18. #16
    Jun 2009
    Kentucky USA
    127
    68
    17
    John
    Thanks John I will pm you my email address.
    I figured these were the threads I canít cut based on missing the 50 & 75 gears.
  19. #17
    Jun 2009
    Kentucky USA
    127
    68
    17
    Quote Originally Posted by Zahnrad Kopf View Post
    I appreciate the communication, but I thought we left it that you would email me when you were going to make a run of the gears again, Have not heard from you and with a #2 & #3 cutter I will have everything I need to make the gears on my Horizontal mill, so I felt like that is something I would enjoy doing. Plus with those 2 cutters I can make a complete set for another friend who has a 10EE.
