I am trying to cut threads on my 10EE for the first time (1943 round dial), and the thread pitches just aren't coming out right. I have been taking some measurements (dial indicator on the compound and rotating the chuck by hand for 4 revolutions) and the numbers aren't coming out as standard thread pitches.
Some of the settings and measurements I have tried:
In the "first position" (where A should give 3 tpi, B should give 6 tpi, C should be 12) I actually get 16.5, 33.6, and 64.5 tpi.
In the "second position (should be 3 1/4, 6 1/2, 13) I get 18.6, 34.7, and 70.7.
Similarly, the feeds seem to be off as well, when I set it to 7.5 thou/rev I actually get 8.4, when I set 1.9 thou/rev, I get 2.4.
The gears on the headstock seem correct to me (that is they should be in the coarse configuration and not metric change gears, I have the 48 tooth stud gear, two 63 tooth idlers, and a 24 tooth box gear).
Any ideas what could be happening here? (For what its worth, this is also the first time I am ever single pointing threads, so it could be something very basic I am missing)
Thanks.
Thanks.
